Sloshing water sound when AC is on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Apr 15, 2023.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    I am getting a running/sloshing water sound from inside the dashboard whenever my AC is on. Anyone have any idea? This only happens when its set for low-temperature, if i set it on heat the noise isn’t there.
  2. Tombukt2
    Tombukt2 Senior Member
    13,799
    2,501
    Durham NC
    What would happen if you were to run a coat hanger gently from underneath the car through the air conditioning water drain hose It's evaporative drain I guess or when your air conditioning is running at a full tilt and pretty much stabilized do you see water on the ground wherever the car's been standing with the air conditioner running? And it shouldn't be just a couple tiny drops if you've been sitting there 5 minutes you should have a pint or so on the ground or half a can or something like Coke can. Sounds to me like water's not getting out of that tube at a good enough rate and some is sitting in your evap case and that is bad.
