Slow A/C operation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Oct 23, 2016.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    When I press the start button there is no output from the A/C for several seconds. Then it gradually steps up from the lowest fan speed to whatever speed the auto setting directs. It can be 10-15 seconds before full A/C operation. I'm used to all the prior "plain" cars that as soon as the engine started the A/C operated at whatever setting was selected. Is there any way to adjust the A/C in the Prius to come online more quickly?
  2. Mendel Leisk
    42,368
    There's this in the Owner's Manual, page 277:
    I think basically it's saying it may take a few seconds to come on,
    I've never noticed much of a delay; 10~15 seconds, as you say. I'd say the delay is because the system is smart, there's no advantage to instant fan response.
    Bluegrassman likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    We have the same delay in our Gen 3. If you think that's bad, don't get a Gen 4. Much longer delay. Have you tried Manual mode by setting the Fan speed manually? I haven't, but wonder if that would help.
  4. LDB
    LDB Member
    279
    71
    I haven't experimented with that yet but I will. The Gen 4 is growing on me as far as appearance but doesn't up the mileage enough to tempt me plus as far as I know there's no solar roof option for it either.
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Remember that either when heat is "demanded" or cooling is "demanded" it takes a little while before there IS heat or cold in the associated energy transfer device (the heater core or the evaporator). The Prius has been programmed to take this into account. If the fan immediately started to blow, you would get warm (or hot) air when you wanted cool, and cool (or cold) air when you wanted heat.
    This is a feature, not a problem. ;)
    Bluegrassman and Mendel Leisk like this.
