Sludge on transaxle drain plug
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dinger_greg, Feb 23, 2011.
  1. Patrick Wong
    18,210
    6,515
    There isn't a lot of space and the radiator may get into the way. Also you may find that a 3/8" ratchet wrench will not give you sufficient leverage since the handle is relatively short (unless you put a pipe extension over the handle, which potentially risks damage to the ratchet mechanism).
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Sorry your right I made a mistake. I missed that.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Not to highjack this thread:), BUT I just changed my transaxle fluid a couple of weeks ago and I failed to follow one of the recommendatins on another thread. Install your fill plug, or either do not remove the fill plug, before removing the drain plug.
    I am not sure about the differences between the Gen II and Gen III, but I removed my drain plug to check the level and then started removing the drain plug. The fluid started out very slow and when I went to unscrew the plug more, it popped out, the fluid hit a cross member and fluid went everywhere.
    By keeping the fill plug in, it helps keep the fluid drain flow at a controllable rate.
  4. Patrick Wong
    18,210
    6,515
    With 2G, if you leave the fill plug in, then the flow of the drained fluid will be glug-glug-glug as air enters via the drain hole. This causes the fluid to splash around and make more of a mess than if you remove the fill plug which allows the drained fluid to smoothly flow out.
    ATF WS has very little viscosity (certainly when compared to motor oil) so it should be pretty easy to clean up if you spill it.
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes, the clean up was not a problem, as you say.
    Could you back out the fill plug slowly until you had some air going around the plug? That is what the other thread seemed to be recommending.
  6. Patrick Wong
    18,210
    6,515
    You could try that.
    However I haven't had trouble with the transaxle oil drain. My process is to put some newspaper on the driveway below the transaxle, then hold up the drain pan near the drain opening with one hand, while removing the drain plug with the other hand. The point of this is to catch the fluid near the drain opening, then slowly lower the drain pan in accord with the path of the draining fluid. No mess, no drips...
  7. dinger_greg
    dinger_greg New Member
    86
    Brookfield, WI
    I backed out the fill plug slightly and that helped control the speed that the fluid drained.
  8. dinger_greg
    86
    Brookfield, WI
    For the fill plug I used a 24mm deep socket with no extension and had just enough room. It was a tight fit though.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    As promised I dug up the old washers and indeed they were deformed at the inner radius:
    but remain flat on the other side and look like may be reused:
  10. dinger_greg
    86
    Brookfield, WI
    They look slightly deformed, but probably could have been used again if needed. Thanks for sharing the pictures. I had a heck of a time removing the drain plug when I changed my fluid. The bolt was torqued very tight. For the fill plug I am going to purchase a standard socket next time I change the fluid. The deep socket I used really limited the room I had to work.
