Sluggish acceleration problem solved!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Anklepain, Sep 13, 2024.
  1. Anklepain
    Anklepain Junior Member
    31
    Finland
    2014 Prius+ MPV
    Solution: change spark plugs to Denso SC16HR11
    My dealer changed my spark plugs 5 month ago to NGK ILKAR7B11 on sheduled maintaince. This cause the acceleration problem to the car.
    It took me 3 month to admit there is something wrong in my car. Took me 2 month to find solution. From now on I will fix everything myself.
    Also Bosch air filter was 5% of the solution. 10% of the solution was from vacuum the hybrid battery fan. 85% of the solution was from spark plugs. The old air filter was also 5 month ago from my dealer. It was PURRO PUR-PA8098 air filter that cause 5% of the problem.
  2. ChapmanF
    19,042
    How did you determine the percentages?
    It would be interesting to see what was showing as the Misfire Margin with the ILKAR7B11, and then after you changed to the SC16HR11.
    BiomedO1 likes this.
  3. Anklepain
    31
    Finland
    2014 Prius+ MPV
    I determined the precentage from my gut feeling.
    I didn't show any dashboard light or OBD code.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I know people who votes like that at the polls and don’t worry about the candidates’ values and policies.
  5. Anklepain
    31
    Finland
    2014 Prius+ MPV
    There is no way im going to put effort and time to get the exact precentage by science.
    The other anwer I can give you is:
    -by changing air filter the car got tiny improvement in acceleration
    -by vacuuming the hybrid air fan the car got tiny improvement also
    -by changing spark plugs the car got huge improvement
    Thats all I got for answer. This didnt change or add any value for the answer either.
    Ps. Im aware of this kind of people. I own a book with 300 pages talking about these stuff. Sometimes people just dont have time or energy to do science. Gotta go with that feeling.
  6. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    So you REALLY only had any improvement when you changed the spark plugs....
    Cleaning the hybrid fan would do nothing to improve exceleration...
    Changing the air filter "might" give you a tiny bit of improvement, "IF" the filter was
    extremely clogged and not allow any air to pass.
    But, I'm glad you resolved the issue. (y)
    #6 ASRDogman, Sep 14, 2024
  7. Mendel Leisk
    42,364
    That seems odd. Dealerships can mess up, but not using the specified plugs? Maybe identify them?
  8. Mendel Leisk
    42,364
  9. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Maybe you had fake spark plugs you know the ones that aren't made by the manufacturer as stated on the labeling that sort of thing real common these days so those hundred thousand mile NGK plugs when they're fake or not even good for 3000 mi in a real world application.
  10. Mendel Leisk
    42,364
    From a dealership no less.
    Tombukt2 likes this.
  11. ChapmanF
    19,042
    The car keeps track of a value called Misfire Margin that can be a measure of how well the spark plugs are doing their jobs. You don't need to have a dash light or OBD code to look at the Misfire Margin; you can pull it up on a scan tool any time. It could have been interesting to see what it was with the other plugs and then after changing the plugs.
    The misfire margin isn't something the ECM remembers, though. It's a value that's constantly being updated while the engine is running, and any time the engine isn't running, it reads as a default value that doesn't tell you anything. So it's probably most useful to datalog the value while driving around, and compare what it was under certain driving conditions.
  12. Mendel Leisk
    42,364
    How did the NGK plugs look when you removed them? Did you take any pictures? Still have them around (for pictures)?
  13. Tombukt2
    13,868
    2,520
    Durham NC
    Hey I imagine with all the funny business going on in the world right now this could happen to anybody
  14. Mendel Leisk
    42,364
    #14 Mendel Leisk, Sep 14, 2024
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    It seems to me (based on experience) that spark plugs bad enough to impact acceleration would cause clearly heard misfire symptoms as the engine to transaxle damper slipped.
    Sometimes a placebo effect is also real in people's minds when in truth no actual change occurs. This is a case where the gut is fooling us.
    Keep us updated.
  16. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    I've been on "both sides of the coin" on this one. I had an intermittent miss under load that the ECU wasn't catching - granted it was an old slow ECU. It turned out to be an intermittent misfiring ignition coil, only under high heat, load, and elevation. It was difficult to nail down because I didn't have my scanner on me when this would happen. When I did run it on the scanner, everything was fine. A couple of times, I've pulled over on the side of the road to try to start pulling ignition coil wires, in an attempt to isolate the problem - only for it to disappear as fast as it appeared.
    I finally shot-gunned it, new set of coils and plugs - It's been two years, not a hic-cup since.... All my plugs and coils ohm'ed out within tolerances, but I didn't put them in the oven to double-check them.
    I tend to use ND or NGK plugs exclusively. I'm starting to include Autolite iridium XP because of their 5 year unlimited mileage warranty, but I recently checked that they've move to a lifetime warranty. I'm still going to replace them every 100K miles. I just hope they keep those rebates up, since they're the cheapest and reliable plugs that are readily available. Counterfeiters don't bother with these....
    #16 BiomedO1, Sep 14, 2024
    wukong sun likes this.
