Small cap found on car floor
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Roqu3, Jul 4, 2022.
  1. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    I was cleaning the cabin when found this little cap in the floor on driver's side, anyone knows where it goes?, doesnt seem to fit anywhere inside the car, thanks in advance
    Joseco08 likes this.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    That style cap is designed to push onto a threaded stud, like a threaded nut
    The gen 2 prius has a plastic storage area in the trunk, on the driverside. The center of the plastic storage insert has a resessed hole in the center, which is placed over a threaded stud on the floor. This locates the plastic in the correct orientation. Then a very similar plastic nut is pushed onto the threads of the stud to lock the plastic piece in place.. Does the C have any plastic storage areas that may have a similar setup?
    Joseco08 and Roqu3 like this.
  3. Joseco08
    Joseco08 New Member
    2017 Prius c
    I found the same plastic cap on my Prius C floor, kept it in the center storage compartment for two years before I finally found where it belongs. The plastic cap goes on a screw on the lower dashboard to hold the panel in place, lower left of the steering wheel near the hood release lever,
    Roqu3 likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Roqu3 likes this.
  5. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Thank you! I´ll check that later!
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    It holds the bottom of the kick panel to the stud welded to the side of the bottom on each side of the car.
    Roqu3 likes this.
  7. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Thank you again, it was like you said.
