Small Chime Noise, what does it mean?
Discussion in 'Gen 2 Prius Technical Discussion' started by jrod81, Jun 26, 2007.
  1. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    this has happened twice now about a week and a half apart... we are driving down the road and a chime noise, almost like a watch clock or something of that nature... could anyone tell me what that noise means??? it is not time for 5000 mile oil change, nothing shows up on the screen or dash...
    help
    thanks
    jared
  2. hschuck
    hschuck Member
    385
    bay city, ca
    <div class='quotetop'>QUOTE(jrod81 @ Jun 26 2007, 09:25 AM) [snapback]468323[/snapback]</div>
    A chime sounds when the last bar on the fuel gage starts to blink. That's probably not it since I doubt that you could drive a week and a half without running out of gas. Some are able to drive from 10 to 40 miles after the blinking starts, ymv.
  3. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I thought it happened whenever there was a warning message on the MSD -- however, the MSD message only lasts a couple of seconds, so ya gotta look quick. Fuel warning is one of those messages.
  4. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    thanks guys, but it is not the gas meter...
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    <div class='quotetop'>QUOTE(jrod81 @ Jun 26 2007, 04:28 PM) [snapback]468490[/snapback]</div>
    I said whenever there was a warning message on the MFD. One of which is low fuel...
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Do you have the Navigation system? If so, the chime may be coming from it, if you are being routed somewhere the system gives an attention chime when you come to turns etc.
  7. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(9G-man @ Jun 26 2007, 05:15 PM) [snapback]468559[/snapback]</div>
    You can also associate what sounds like a loud doorbell chime with a specific location, though I doubt that's it. The Prius is full of chimes and dings that are very context specific. When it happens again, try to note the situation.
  8. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    And sometimes you may just miss it . . .
    Were you by chance driving like a nut . . . or crossing over or driving on a slippery surface?
    If so, it could be the Vehicle Stability Control warning chime.
  9. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Was it three beeps? If the Smart Key System loses communication with the remote, such as when you get out of your car and close the door with the car still running, it will beep 3 times. The beep is outside and is not real loud inside.
    I would assume that if your were driving around and the Prius thought it lost communication with the SKS remote, it would beep 3 times.
    Do you keep your SKS remote next to a cell phone while you are driving? Like maybe in the same pocket?
  10. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    the chime might be associated with VSC or ABS.
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Could you be bumping the shifter with your knee? I got a chime today when I accidently bumped it while backing up...that could account for the rare and intermittent nature of the beeps.
  12. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    thanks guys for all the help... i will try to pay attention to these choices next time it happens. i am thinking it is the traction control bc one of the times i am about 99% sure i was on bridge
  13. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(jrod81 @ Jun 28 2007, 12:27 PM) [snapback]469499[/snapback]</div>
    Traction control does not beep and being on a bridge (unless it was wet and you were trying to accelerate from a stop or low speed) wouldn't cause traction control to kick in.
    VSC will cause a triple beep, but you'd probably know the cause b/c you'd be at the edge of control or in a slide and you'd feel the system briefly take control of your car to correct for the slide. The dash will flash an icon, but it's unlikely you'd see it since driving would have all your attention in such a tenuous situation.
  14. statultra
    798
    31
    Edison,NJ
    2001 Prius
    ABS makes a very loud and annoying chime when there is a severe problem with the ABS system.. i have experienced this on a 01 prius
  15. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    i guess i could take it into the toyota dealer but i wanted to have some sort of idea of what was going on? i will just take it in i guess and see what they say.
  16. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(jrod81 @ Jun 29 2007, 08:17 PM) [snapback]470358[/snapback]</div>
    I started hearing a quiet little beep in my car. Went through most of the possibilities mentioned by the other posters. Finally noticed it with the car stopped. It turned out I had missed messages on my Verizon Razr V3 phone that was in the console. That phone/service does an occasional beep in that circumstance.
    - Tom
  17. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    door open.
  18. cocamper
    cocamper New Member
    Colorado
    I believe the chime is the Entune system trying to connect to your phone - or some other phone in the car. Try turning off the Bluetooth on all phones and see if it doesn't go away. It worked for me.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    It's a 10 year old thread.
    b100 likes this.
