Small crack on engine near PCV Valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DevChatt, Aug 17, 2017.
  1. Mendel Leisk
    42,365
    Yeah even to check your AA battery collection, rudimentary multimeters are really a cheap commodity these days. Didn't stop me getting the Milwaukee RMS meter though. :oops:
    Then, google "solar BA5", for an entry level electronic tester, around $60~70?
    Raytheeagle likes this.
  2. Mendel Leisk
    42,365
    Man, you pretty much live on here. :ROFLMAO:
    I should talk...
    Raytheeagle and SFO like this.
  3. DevChatt
    DevChatt Junior Member
    92
    31
    Bethlehem Pennsylvania
    Aha, unfortunately we don't have a Harbor freight near us. I'll stop by an autozone tomorrow and see if they can scan codes...this is the same tool they use for check engine light warnings and such right?
    Scratch that--- I just did a better google search to figure out what it is exactly...yeah I went to AAP and they said they didn't wanna touch it because...prius.
    May try autozone for my luck although.
  4. Mendel Leisk
    42,365
    If they're afraid to check 12 volt on a Prius, you better keep them away from it, they sound incompetent lol.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Is that the pot calling the kettle black:whistle:.
    Today was draft day in 2 of the fantasy football leagues i am in. So I was at a computer more than usual today;).
    Still not here as much as some(y).
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    There are Harbor freights around your location of Bethlehem:
    Harbor Freight Tools Stores - Search Results
    We were just at the Crayola Factory in Easton at the end of July and went by one of the Harbor Freights(y).
  7. DevChatt
    92
    31
    the things you learn.
    I for one have never been in one. Must put it on my list now.
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    It can be like Prius Chat: addictive(y).
    DevChatt likes this.
  9. Mendel Leisk
    42,365
    Home Depot too. Most any hardware.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    The closest auto parts store to me is Advanced Auto Parts. Those guys are about the rudest and least competent I've ever seen in the business. I don't go there anymore. As @Mendel Leisk said, if they are afraid to load test the 12V on a Prius, run away.
    We have an Auto Zone nearby. They seem good. I hear good stuff about Pep Boys if you have them around. But, as Mendel and Ray said, it's not hard to do a basic check with a meter, and no home should be without a multi meter. I haven't invested (yet) in the BA5 Mendel likes because I can generally figure out with a multi meter whether I need to take the battery to a shop for further testing.
    Mendel Leisk and Raytheeagle like this.
  11. DevChatt
    92
    31
    Gonna go hit the autozone today after work just because of the results from testing.
    But funny thing...
    I got a "Check tire pressure" light on yesterday driving around. Therefore I decided to reinflate the tires to the proper PSI levels as noted...
    AND GUESS WHAT
    My MPG returned to 47-48.
    Sometimes it's the simple things that cause the issue. I must of somehow reduced my tire pressure while working on the car I guess.
    jerrymildred and Raytheeagle like this.
  12. DevChatt
    92
    31
    Agh, Autozone doesn't do the testing either I have learned. Well atleast the one i went to.
    I asked them for a battery test then said it was a prius. Immediately one of the other reps said "No, we definitely do not do prius's"
    and then he told me a story of how someone short circuited a prius a while back and it cost the shop 15k in damages...ouch.
    Eitherway...figure that is an interesting story to share.
    Will try another autozone tomorrow...and then maybe a pepboys/ monroe (i got my PA state inspection at the beginning of the month so i may be just able to combine these things...)
    I'm just happy my MPG is back up and everything seems to be running fine. Crazy how everything was somehow related to one underinflated tire!
  13. jerrymildred
    11,517
    14,171
    Tampa, FL
    Ouch is right!! I wonder how they managed that and why they apparently had to replace the whole car. :eek:
    Just take the battery out and go over to the place and set it on the countertop and see if they are still afraid of it.
  14. NandoEM
    NandoEM New Member
    Fort Myers
    Same area I had my problem with except I kept going since I dropped my worklight. Turns out the noise I heard wasn't just the PCV valve. You think Toyota designed it this way on purpose? It's damn near impossible to change it because of the valve cover. I went straight through though like a beginner mechanic. I haven't really done engine work since I had started chemo treatments back in 2013 though. Maybe I'm too rusty. I'll have to be much more careful next time. My dad would roll over in his grave if he knew about this.
  15. Mendel Leisk
    42,365
    Yeah you've GOT to use a socket, to play it safe. That thing is just a trap: it's tempting to put a wrench on it, and there you go.
    Take the valve cover off, fish out the broken piece, clean/dry everything with alcohol, fit the piece back with JB Weld or similar.
    #55 Mendel Leisk, Sep 17, 2018
    NandoEM likes this.
  16. NandoEM
    NandoEM New Member
    Fort Myers
    I wanted to... I really did, but I needed more room which meant taking out the coolant reservoir. Not making that mistake again. Next time, provide yourself extra work room or don't do it at all. I ordered a new valve cover and gasket to replace this one. I'm also having an issue on the 3rd cylinder removing the Spark plug. Thing keeps spinning like a boot is stuck in it or a rubber piece from a spark plug socket, but mine is still in one piece. This time I'm bringing it to Toyota after i change the cover since it was running fine prior to me working on it
  17. Patrick Wong
    18,210
    6,526
    Remove the sheet metal tray that runs across the back of the engine compartment, so that you have good visibility and access to the spark plug wells. Then you can easily see what is wrong with the third cylinder spark plug well.
    Don't be afraid to remove the tray, it takes about 10 minutes once you are familiar with the process. Remove the windshield wiper arms. Remove the rubber gasket that runs along the length of the tray. Remove the two black plastic tray cover pieces below the arms. Remove the relay box that is bolted to the tray.
    You probably have to replace the plastic fasteners at the ends of the black plastic tray covers since they will get fragile with age and exposure to the sun. Then you can remove the windshield wiper motor, and the bolts that hold the metal tray to the car body.
    This give you access to lots of items such as the rear of the inverter, the brake actuator, and of course the top of the engine.
  18. ChapmanF
    19,045
    Use your open end, but figure out first what angle it can reach before touching the valve cover, then lay a wood block or something ahead of it on the cover so it can't?
    I can't easily go try it; I have a Gen 3 now, with its PCV valve in a whole different evil place.
    -Chap
