small motor running rear of car
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Thebearded1, Sep 14, 2022.
  1. Thebearded1
    Thebearded1 Junior Member
    Maryland
    2016 Prius c
    Today when i got home I heard the noise of a small motor running under the rear of my wife's 2016 Prius C. The car had been parked for at least 6 hours and was off, this one has a key not a push button start. I crawled under there and could tell the noise was coming from this.
    I looked at various parts diagrams for this model prius but couldn't find it labeled. Does anyone know what this is?
    We started the car and the hybrid battery was 3/4 charged and was likely not fully charged when parked. The gas engine started fine and when we turned the car off the noise from under the rear had stopped.
    I can imagine why anything would have been running. The car was not hot inside, it was parked in the shade and it was only 70 F degrees out today. Has anyone else had this issue?
  2. PriusCamper
    PriusCamper Senior Member
    12,771
    5,174
    Pacific Northwest, USA
    Well, this car is slightly different than a regular Prius and haven't experienced it with a Prius C before, but the regular Prius has a sniffer to check for leaks in the fuel system that would be similar to what you're describing. I'm sure if you look in the owner's manual there will be an explanation of the noise you might hear when car is turned off.
  3. fuzzy1
    10,454
  4. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Almost every gasoline-fueled car made in the past 15-20 years has a variation of this. Completely normal, nothing to be concerned about.
    alanclarkeau likes this.
  5. Thebearded1
    Maryland
    2016 Prius c
    Cool glad to hear. Never noticed it with my truck or any other vehicle i've owned
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    Not all cars have that kind of pump that makes noise, but there is some system that checks the fuel tank and fuel vapor system for leaks.
