Small rattle when accelerating
Discussion in 'Gen 3 Prius Main Forum' started by Rickyland, Sep 26, 2022.
  1. Rickyland
    Rickyland Junior Member
    Four Touring
    I was driving a 2015 Prius, recently, when it went from 0-20 mph normally. Stepping on the gas pedal lightly to accelerate the car from 20-30mph appears a small creaking sound under the car, above 30mph the car runs smoothly normally. Please tell me what is wrong with my car?
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    Well creaking is generally not descript of head gasket . Look more for a bucking kinda feel.. creaking and groaning descriptions are usually something to do with suspension I've noticed.
    52,858
    loose aero cover or heat shields?
    how many miles on her?
  4. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Check to see that the "stick" that holds the hood open is secured in it's clip. Mine has weakened and if I shut the hood too hard the stick will fall loose and lay on the engine. It makes a small rattle as you say when gently accelerating. I don't think it would hurt anything but now that I recognize the rattle, I can replace it and close the hood a bit more gently.
  5. bettergolf
    495
    370
    Sanford NC
    This looks like a double thread...I replied in the other one.
