Smart Key Issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pastorkenny, Oct 27, 2018.
  1. pastorkenny
    pastorkenny New Member
    Newport News, VA
    Help! Here's what I got...
    • 2007 Prius with smart key system (silver logo on the fob)
    • Just changed the battery on my key fob
    • The fob locks and unlocks the doors when I press the fob buttons
    • The fob in my pocket doesn't allow me to open doors using smart key sensors
    • The fob in my pocket doesn't allow me to start the car. I have to insert the fob.
    Here's what I already tried...
    • the "key" button under the steering wheel
    Here's what I'm NOT gonna do...
    • Go to the dealer
    49,516
    test the health of your 12v battery
    when it starts to get low, the range decreases as you describe
    my '04 did the same exact thing. fob buttons worked, but not sks
    pastorkenny likes this.
  3. JC91006
    16,486
    8,401
    Is this car new to you? Did sks ever work? Is the button under the dash labeled SKS?
  4. pastorkenny
    Newport News, VA
    Its not new. The SKS has worked for over two years now and only stopped when I replaced the fob battery.
  5. pastorkenny
    Newport News, VA
    So the battery test says I'm getting 13.9v out of my 12v battery. Seems weird eh?
    #5 pastorkenny, Oct 27, 2018
  6. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    13.9V is likely with the car READY? READY is the equivalent of the engine running, recharging the 12V battery. If this is what you did, you are measuring the Voltage as the 12V battery is getting recharged.
    Read post #5 & #8. Is my inverter coolant pump slowly failing? | PriusChat
    Post 5-quick easy way to load test the 12V battery
    Post 8-SOC (State of Charge) chart, some smart, AGM compatible 12V battery chargers.​
  7. exstudent
    2,213
    901
    Torrance, CA
    Is the FOB battery the correct one? Test the FOB battery to rule it out.
  8. bisco
    49,516
    if you are saying you replaced the fob, that may be the issue.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Seen a few posts about people taking there fob apart and the tiny little rfid module falls out. It’s a tiny little black piece Attached to the inside of the fob body. If rfid is not in the remote it will act like your scenario.
  10. JC91006
    16,486
    8,401
    His works in the slot, missing sks functions. RFID chip will affect our working in the slot only
    It sounds like his sensors in the door and center console are not working.
