Smart Key Issues
Discussion in 'Gen 2 Prius Technical Discussion' started by Lexi, Feb 19, 2019.
  1. Lexi
    Lexi New Member
    Knoxville, TN
    I have a 2006 Prius that has been giving me issues. The key fob will only work 50% of the time. The other 50%, touching the door handle will not unlock the car, and the car will not start. It will flash the yellow & red no key lights. If I continue pressing the start button for 5-10 mins it will eventually randomly start.
    I have tried:
    - Replacing key fob batteries
    -Testing 12V (it is fine)
    - SKS bytton turning on/off under steering wheel
    This morning, I tried to have a new key fob made as I thought that might be the culprit. The locksmith told me that it would not allow him to program the new key in to the proximity sensor. He also told me the car does not show that it registers or recognizes the old key. When put in the ignition slot, the old key is not registered. When put in the ignition slot, the new key is registered and will start the car.
    He suggested the proximity sensor may need to be replaced. Does anyone have any experience with this or know how to replace it?
    Thanks.
  2. JC91006
    16,936
    8,647
    Does this problem only happen in the driver's door? There are sensors on both driver's and passenger door. As well as rear hatch and center console.
    If the problem is happening in all areas of the car, it's probably not a sensor problem. It would be related to a keyfob.
    Try changing the battery from the NEW fob to the OLD fob. See if that changes anything. If your old keyfob works after the battery swap, then you know your problem.
  3. Lexi
    Lexi New Member
    Knoxville, TN
    I’m a little confused how to respond to this. It seems like you didn’t read my post correctly. It’s 100% not a key fob battery issue.
    52,861
    welcome!
    i think it is under the center console, iirc. you might also have an eco issue. could be a wild goose chase.
    might be worth hooking up tech stream and looking for codes, or having a dealer take a look
  5. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    You're assuming the battery you used to replace the one in the key fob was good. JC is not making that assumption, and doing what he suggested will prove/disprove that assumption.
    It would be helpful to just answer the other questions posed as well, as they are reasonable questions and once having the answers, he/we can go to the next steps.
    Skibob likes this.
