Smart Key/Keyless issue: works randomly, different handles respond, someting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kamilpcc, Aug 11, 2025.
  1. Kamilpcc
    Kamilpcc New Member
    Polska
    I’m having an issue with the Smart Key/Keyless system in my Gen 2 Prius and I’m wondering if anyone has experienced something similar.
    Symptoms:
    The car starts fine with both keys (both when inserted and without inserting – the transponder is recognized).
    The problem is with locking/unlocking the doors using the handle (keyless) and sometimes with the remote buttons.
    The LED on the key fob blinks when trying to lock, but the car doesn’t lock.
    Sometimes the driver’s door handle works, sometimes only the left rear door handle works, and sometimes neither.
    Sometimes the trunk button will lock/unlock, and then it stops working again.
    Sometimes the keyless works perfectly in the morning, but after a few hours of parking or even after a short drive it starts acting up.
    Occasionally, the handle button only works if the fob is close to the rear antenna (near the rear door), but not from the front.
    On the dash, I sometimes see the orange “car with a key inside” indicator (not the golden immobilizer one) blinking.
  2. JC91006
    16,939
    8,647
    Have you tried changing the battery in your FOB?
    Brian1954 likes this.
  3. Kamilpcc
    Kamilpcc New Member
    Polska
    I've replaced the batteries, but that didn't help. It just works randomly, or sometimes it detects the key inside and I have to insert it into the drawer. Sometimes I don't even know what's going on.
  4. Kamilpcc
    Kamilpcc New Member
    Polska
    One more thing, what does the AGM battery have to do with this? I'm looking, and I don't know where to look. Why did the antennas suddenly fail? Apparently, they're in the door handles. And suddenly everything worked, and it got worse and worse. I was curious about the AGM's voltage. It's 12V. When I turn on the ignition, it drops to 11V, and then to 10.6V after a while when I turn on the lights and blower. But even if I turn on the ignition and charge the battery, it doesn't change the operation of the SKS (keyless) system. The best part is that when I press the button on the door handle, the LED in the remote flashes, meaning they're communicating, but the car isn't following the command, or the remote isn't sending this information to the car. I don't know what I'm talking about anymore.
  5. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Do you have the troubleshooting section for the manual it's almost one complete book? A guy posted in another similar thread you should try n get it . Looks like complete manual set online . You will need it it is extensive paper and pen. Is a must.
  6. bisco
    52,889
    get a 12v load test
  7. Kamilpcc
    Kamilpcc New Member
    Polska
    Unfortunately, I don't have such instructions
    Can you explain to me what you mean and how to do it???
    #7 Kamilpcc, Aug 12, 2025
  8. Kamilpcc
    Kamilpcc New Member
    Polska
    And now the best part. This morning, I started the car without any problems. I live in a housing estate. I went into the menu, the AGM voltage was 11.7V, and I drove to work. I have clean air at work, no buildings, and absolutely no problems.
  9. Kamilpcc
    Kamilpcc New Member
    Polska
    It's already been revealed what's going on. I've replaced the AGM with a regular Bosch S4 lead-acid battery. I wonder if my fuel consumption will improve if I install the AGM, as many people have written that the AGM has a huge impact on fuel consumption.
  10. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    As long as the battery is in good condition, it will make no difference.
    The Bosh S4 is a regular flooded lead/acid battery. It probably will not last as long as an AGM.
    There are advantages to the AGM chemistry, but better fuel economy is not one of them.
    You may experience a negative impact on fuel economy if any battery (flooded or AGM) has a shorted cell or similar issue.
  11. Kamilpcc
    Kamilpcc New Member
    Polska
    Okay, I understand. Well, it's dropping to 10.9V, so that's not good. My question is, is fuel consumption of 5.2-5.3 liters of gasoline okay, mainly in the city and on short trips? Do I need to work on my technique? And why is it that after driving during the day, my battery is almost empty according to the MFD screen, but when I drive to work the next morning, it's either below 50% or even at the limit? Does this mean my HV battery needs checking?
  12. Kamilpcc
    Kamilpcc New Member
    Polska
    and could this be the reason why my keyless system is malfunctioning?
  13. dolj
    dolj Senior Member
    8,652
    4,404
    No, that is not good. Have you charged this battery up? If not, then I would advise you to do that then test the battery. I understand this is a new battery, but it is not giving the results you would expect from a new battery, so you need to ensure the 12 V battery is healthy, otherwise you could end up chasing your tail.
    It's not awful given the city and short trips. There are so many things that can affect fuel economy, so it is hard to say what you might do to improve your numbers. If you could get 4.7 L/100km, you would be happy with that.
    Hard to say, but it does not necessarily mean you have HV (hybrid vehicle) battery is having problems. If you haven't done any battery reconditioning, that might be something that you could look into.
  14. Tombukt2
    13,875
    2,521
    Durham NC
    Gas mileage issues make sure nothing dragging top of small hill neutral the car should fly down hill like soap box derby car . Google it . You should hear no scraping dragging but the wind is down we're trying to hear stuff slowing us. If hi mileage HV battery wen ya change you will notice mpg changes you mite not see 55mpg . Just remember you're driving a 20-year-old gas saver reg cars are catching up in mpg. You still getting better mpg than most for like 2500 bucks. They makin payments
  15. Kamilpcc
    Kamilpcc New Member
    Polska
    This 12V battery was already in the car when I bought it. The HV battery has never been rebuilt. I once checked the difference between the cells with an app, and it showed 0.17V-0.2V, but I'd need to do a more thorough test. Overall, the Prius learned to drive very stupidly, and it forces itself to run on electricity wherever possible. 4.7 liters per 100km? I've never had a result like that before, and I don't know what I'd have to do to get it below 5 liters. The car has 260,000 km. Right after buying it, I changed the oil, spark plugs, and water pump. The car doesn't use any oil or other fluids. It doesn't jerk. I'll wait for a cable and connect it to the computer to see if there are any errors. I'd just like to get it below 5 liters, as an experiment, to see if I can actually do it.
  16. Kamilpcc
    Kamilpcc New Member
    Polska
    Oh, and I think I've found the cause of the keyless entry system's glitch. It's probably buildings or some devices that are interfering with the system. If I park somewhere else, everything works fine.
  17. Tombukt2
    13,875
    2,521
    Durham NC
    Well that's great yeah things like that can happen I guess the airwaves are logged in places .
