Smart Key Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bertaman, Nov 17, 2016.
Tags:
  1. bertaman
    bertaman New Member
    Arkansas
    Hello all, I just bought a 2006 Prius. It only came with one keyfob (silver logo) and to my eyes, has all indications of being a "smart key". However, the lock and unlock buttons on the fob do not work, and the automatic lock/unlock feature doesn't work either. The only functional part about the fob is that when inserted into the ignition, it starts the car. I have changed the battery and checked the "key" button underneath the steering column. Is there anything I can do without taking it to the stealership and paying $200+ for them to fix it? Thanks.
  2. JC91006
    16,482
    8,400
    Have you tried changing the battery on the key fob?
  3. bertaman
    bertaman New Member
    Arkansas
  4. JC91006
    16,482
    8,400
    That's probably not the original key fob to the car. Just a replacement programmed to start the car when inserted.
    There's a small metal key in the key fob, does that metal key work on the car lock on the driver's door?
  5. bertaman
    bertaman New Member
    Arkansas
    Yes it does.
  6. JC91006
    16,482
    8,400
    check the key fob and make sure all 3 buttons click without sticking. There's also a little red light on the key fob that lights when you press a button.
  7. bertaman
    bertaman New Member
    Arkansas
    The light comes on, and none of the buttons are sticking.
  8. JC91006
    16,482
    8,400
    when you press the button on the driver's door outside handle, does the car lock with all doors closed? how about on the passenger side?
  9. bertaman
    bertaman New Member
    Arkansas
    No, the car does't lock from either side.
  10. JC91006
    16,482
    8,400
    when I press the buttons on my key fob, the light on the key fob is RED, not green as you posted.
    Maybe you can try another battery for the key fob?
  11. bertaman
    bertaman New Member
    Arkansas
    I don't see where I said it was green, but if I did, my mistake. The light is red. I have tried 2 batteries.
  12. JC91006
    16,482
    8,400
    I must be seeing things on the green part....
    Anyways, I'm out of ideas. I think you've covered all the areas that you can possibly cover. It may just have lost it's memory and need to be reseeded and programmed again. If you choose this option, go buy a USED or NEW keyfob and have it programmed at the same time during the reseeding. You'll want the spare.
    Absolute last idea would be to reset the car's electronics. Disconnect the 12v battery for a few seconds. You'll lose your memory presets on the radio and your auto up/down on the driver's window. To fix the window, just hold the window up switch for 5 seconds after the windows closed.
  13. bertaman
    bertaman New Member
    Arkansas
    Okay, thanks for your help
  14. bertaman
    bertaman New Member
    Arkansas
    Oh, and is it possible to reprogram with only one fob? All of the instructions I can find involve 2 fobs.
  15. JC91006
    16,482
    8,400
    you need to pay someone to reseed the car's keyfob memory. That will erase everything and add what you have in your hand. you can do 1 or up to 5. But if you are going to pay for that expense, you should have a spare done at the same time. That's usually done for free
  16. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Have you checked the 12V AuxBattery? I found that when my SKS system started to get flakey, the root of the problem was a failing 12V AuxBattery. This happened last year, when the 12V battery on my 2009 Gen II was about 6 years old and had never been replaced. hope this helps - Good luck - Wil
  17. bertaman
    bertaman New Member
    Arkansas
    I will have the dealer check this. Thank you.
