Smart key question..
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CLUBGUY, Sep 14, 2013.
  1. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    If the battery in the key is removed, will the memory/data in the key be lost..????
    I want to hide the key less the battery in the vehicle....
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Nope! It should retain the data code. Try it for a week and retest it just to see (y)
  3. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Thanks....Will do..!
  4. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Some claim wrapping the remote in foil will 'hide" the remote from the car. Then you don't have to remove the battery.
    SCH-I535
    xpcman likes this.
  5. GerryL
    GerryL Master Model Railroader
    170
    23
    Minneapolis, MN
    I just replaced the battery in my remote, which involved removing it for a few minutes. Works just fine with the new battery.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    If you want to hide an emergency keyfob it is perhaps best to remove the battery. Use the mechanical key (or a copy) to lock/unlock the driver's door, and hold the batteryless keyfob next to the Power button to unlock the ignition. You could tape the battery to the outside of the emergency keyfob so that you could install it if you want to restore full smart function. Or maybe even remove the circuit board from the case - even if someone found the circuit board they probably wouldn't understand that it was an ignition key :LOL: .
    I recommend trying a batteryless keyfob just to learn how it works. The range is really short, like touching the Power button with the correct side of the keyfob. Best to experiment at your leisure, rather than when the main keyfob goes missing.
  7. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Thanks....very helpful..
