Smart Key Questions
Discussion in 'Gen 3 Prius Main Forum' started by Albert Brizendine, Jul 4, 2013.
  1. Albert Brizendine
    Albert Brizendine Junior Member
    Can you have more than the two that come with the car and is one considered a "master" or are all of the them same? I may need a third one for another driver.
    What is the button for on the left side of the Smart Key?
    It has the word "Push" on it and a picture of a key.
    Is it possible to change the battery in one, should this ever become necessary or do you just have to replace the entire thing?
    52,863
    yes, you can have as many as you want and there is no master. they are expensive however. the 'push' button releases the metal mechanical key to unlock the door if the battery dies. and the case opens up to reveal a relaceable watch type battery. it's in the manual. all the best!(y)
  3. Albert Brizendine
    Cool. Never knew it had a mechanical key. Thanks.
  4. Lindsi
    Lindsi Junior Member
    44
    Mishawaka, Indiana
    Our salesman said if you are out and the battery in the fob dies, use the physical key to get in and if you hold the fob next to your start button, it charges it...just enough so the car recognizes it so you can start it. After 6 months, I have no way to test this yet, nor have I really looked in the manual.
    I'm doubtful on the fact that it charges it, but thats what he said (he was kind of an idiot tho), I'd assume in reality there is a tiny charge left and with the key close enough it can recognize it.
    Either way, I hope its true just in case...
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You can have up to four, actually. Unless they have changed the GIII from the GII.
    Holding the FOB up to the start button doesn't actually charge it, it energizes the RFID chip inside and reads what it reply's with. Same as a "paypass" credit card. With a good battery in the FOB you can leave it in your pocket/purse.
    The car won't want to lock with the FOB inside. It will emit three beeps outside to warn you.
    When the FOB battery gets weak you will see a key appear on the dash warning you. It's easy to replace. I posted the battery type a while ago for both the GII and GIII (they are different).
    After watching how people drive these days, I'd say it's MUCH smarter than most of us. ;)
  6. Lindsi
    44
    Mishawaka, Indiana
    You can lock one fob in the car by using another fob to lock the doors... This blew our mind the other day when we accidently did this.
    SCH-I535 ? 4 Beta
    plamadil likes this.
  7. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    I find that 2 1/2 to 3 years you will need new batteries buy them anywhere and you can change them yourself and you can always toss a extra battery in the glove box
  8. Albert Brizendine
    Does the case just pry open for a battery replacement? I don't see any screws on mine.
    Also, when I called the dealer about getting a spare, they said something about using a laser when programming a new Smart Key. What would that be about?
  9. MPGnutcase
    579
    114
    Chicago
    yes they pry open, not sure on programing a new one. Normally when you have the 2 org. fobs you can buy a 3rd FOB online [aka Ebay] and do it yourself.................... if you lose one the dealer must do it and you need the silver tag hanging on your spare remote
  10. MPGnutcase
    579
    114
    Chicago
    Appox $50 for a FOB and $90 with the A/C button on it
  11. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Prepare for some sticker shock on buying another fob from a dealer. About $250 for the fob, plus $100 to pair it with the car.
    Best deal is to get a used fob off eBay and have a locksmith set it up. But first you've got to find a locksmith with the right equipment.
    Another option is to purchase a new fob from an online dealer (about $150), and pair it by using the chicken dance. You'll still have to get the mechanical key cut ($35+).
  12. RobH
    RobH Senior Member
    2,385
    991
    70
    This isn't supposed to happen. Either the fob left in the car has a bad battery, you hid it in some corner of the interior where it couldn't be sensed, or something is wrong with the key system. It would work this way with a 2004=2009 system without SKS (black logo keyfob), but your profile says a 2012...
  13. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Incorrect. It is possible to lock one fob in the car using the other one from a distance. But only if the car is off.
    Lindsi likes this.
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Agreed. The SKS system prevents locking a keyfob inside the car, but only if you use the button on the doorknob.
    This is really good to know as there are times when you want to leave a keyfob inside the car. If you depend on the door handle button to lock the car, I thought the only way to lock it was to use a mechanical key. So all you need to do is use the lock button on the fob.
  15. bisco
    52,863
    doesn't it unlock when you put your hand on the door?
  16. Roger2974
    Roger2974 New Member
    Turned in the iV , bought an III 2010, miss the hatch door opener, Any one know if you can add this feature on to the car for the hatch open .
  17. RaZa
    RaZa Member
    480
    93
    An interesting thing about the metal key is the bottom of it is designed to fit in the hole to pry the fob open.
    Nora likes this.
  18. David Beale
    5,963
    1,990
    Edmonton Alberta
    To add a FOB they need to cut the key to your car. That uses a laser. Then they need to program the car to accept the FOB. Finally, I'm told they need to program the FOB to accept the car.
    Last I heard, the car can accept up to four FOBs. Not sure if that has changed with the GIII.
  19. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    There is a thread about how to do just that. Be advised to have someone do it for you would cost hundreds of dollars.
