Smart Key Replacement Cost
Discussion in 'Gen 3 Prius Main Forum' started by geeter, Jan 1, 2013.
  1. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    Key alone about $140
    Key and programming about $250-400!!!
  2. HGS
    HGS Member
    307
    123
    I bought a new fob from Toyota online for $130. I programmed it to my car myself.
  3. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    More info would help people.... 130, plus key cut? plus software/hardware?
  4. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    would you be kind enough to run us through the programming??
  5. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    The "programming" is done through Techstream software and a miniVCI cable connected to a PC. You should own a miniVCI cable and TechStream regardless because you can change many things about how the car behaves such as disabling the continuous rear beep and seat belt chimes.
    You can purchase a miniVCI adapter on Amazon for $18 and it will come with the TechStream software.
    Install the software in a 32 bit Windows environment.
    Plug the USB end of the miniVCI adapter into a computer and the other end into the OBDII port on the Prius (Below the steering wheel where the plastic ends, just like most every car.
    Turn the Prius on.
    Disconnect the PC from the internet and then run the TechStream program.
    Follow through the menu to add the new key. It has instructions on what to do built into the software.
    Read through this post because you may need to modify a file if you get an error.
  6. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Do I need to have a TechStream active subscription in other to program this?
    XT1060 ?
  7. Redpoint5
    1,026
    509
    Portland, OR
    No, which is why you disconnect your PC from the internet connection before starting the TechStream software. It tries to authenticate the subscription if you have an internet connection, but allows you to run the program if you don't.
  8. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Ooh OK. Cooool!!!!
    XT1060 ?
  9. 23stks
    23stks New Member
    Los Angeles
    I just bought a replacement remote for my 2015 Prius II online at the ReplaceMyRemote website.
    I was going to take to a local auto locksmith to program it for me but just came across your post; would I be able to do this at home then with your method? I consider myself pretty tech savvy; just wanted to double check.
    Thanks!
  10. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    If you have Techstream/MiniVCI you can program new (or virginized) fobs yourself.
    If they are used FOBs you need a passcode calculated and "seed reset", much trickier.
    When you install techstream, find file IT3System.ini and change TISFunction = 1 to TISFunction = 0
    Then it won't check for network or try to authenticate software
    The ini file is often located here; C: Program Files \ Diagnostics Toyota \ Techstream \ Env \
    23stks likes this.
  11. Redpoint5
    1,026
    509
    Portland, OR
    I couldn't get Techstream to run on a 64 bit OS, which is what most computers come with nowadays. Instead, I used my wife's old laptop which had 32 bit Windows 7 installed.
    I'm not sure how to get Techstream to work on 64 bit. Perhaps it can be run in a 32 bit VM.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Try running it as the administrator in Windows 64 bit and run at 32 bit VM. That should do it. I don't have the software, but I am a geek. Good luck.
  13. 23stks
    23stks New Member
    Los Angeles
    Can't seem to program my new smart remote for my 2015 Prius; I'm running the latest Techstream software on a Windows 32bit laptop with XP. I got my remote from ReplaceMyRemote online and they said it was new.
    I went thru the whole smart key registration process (touch registered key, touch new key, never having both keys in car at same time) but at the end it says registration failed. What could be some possible reasons?
  14. Onex Prius
    Onex Prius Junior Member
    Puget Sound WA
    Your new key is not NEW!! It been programmed before. The key may look new but it actually not.
    That's the only reason your key registration failed. Contact the seller and return it. Look on ebay for seller that state New key never been programmed.
    Good luck
    23stks likes this.
  15. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    I agree...Look on ebay for NEW(from online toyota dealers) or look for sellers selling "Virgin" keys.
    23stks likes this.
  16. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    One possibility is that the car requires an AAB remote. Most remotes sold "for 2010-2015 Prius" are ACX.
  17. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    Have never seen AAB on a 2015. None of my key shops have reported that either. All aab reports have come from 11 and 12 only.
    23stks likes this.
  18. BobcPDX
    BobcPDX Junior Member
    Portland, OR
    Ovni, are you now selling remanufactured fobs on Ebay? It looks like you, and it looks like you've learned how to reset the keys so that they act like brand new keys? Way to go! I'll be a customer right away - bought a 2010 that only came with a single SKS fob. Ugh! Got paranoia? Hoping to make a couple spares, pronto!
    Thank you for your contributions!!!
    Bob
  19. bisco
    52,849
    is it the same pic as his avatar?:p
  20. Mendel Leisk
    42,343
