smart key - unlock TWO doors?
Discussion in 'Gen 2 Prius Technical Discussion' started by MattFL, Jan 13, 2008.
  1. MattFL
    MattFL Member
    168
    48
    I've got the 2008 Prius, package 2 with SKS, currently configured to open only the drivers door when the drivers handle is grabbed. I want both drivers side doors to unlock when the driver's handle is grabbed, but NOT the passenger side doors. Is there any way to do this? My wife takes our 2-yr old son around and she needs to unlock the back driver's side door to put him in the child seat, but we DO NOT want the passenger side doors to unlock at all for safety reasons.
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    No. Not without something aftermarket or do it yourself.
  3. Tideland Prius
    16,211
    Nope, can't be done. In fact, I know of no cars that actually do that. It's usually driver's only or all 4 doors (5 if it's a minivan or SUV or hatchback with power hatch/tailgate releases).
    Couldn't you just reach over and manually unlock the rear left door? It should be easy enough to reach.
  4. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    A good car electronics installer should be able to set up an alarm system with specific control of one door, or, in this case, the left doors. It's not an everyday request, so they'll have to think about it and it may cost a little more than a standard installation.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Alternately, you can disconnect the electric door locks on the passenger side, then set the SKS to unlock all doors. Of course, if you do that, you will have to manually unlock the passenger side.
    Tom
  6. westex39
    westex39 New Member
    60
    Grab the passenger side door handle. It will open all the doors.
  7. MattFL
    MattFL Member
    168
    48
    Thanks everyone, after reading the manual I was afraid this was not possible. :( The goal is to get my wife and son into the car asap without unlocking the passenger doors. She's usually carrying my son and an arm load of stuff so it's difficult for her to open the drivers door to get to the back locks. We've had some abductions, murders and robberies here lately so getting in the car ASAP without having to stop and fumble for anything is of high importance. I'll probably end up configuring it to unlock everyhing when the driver's door is grabbed.
  8. G0ldenchild562
    G0ldenchild562 New Member
    How do I program it so all doors unlock?
  9. JHSmith
    JHSmith 2020 Avalon Hybrid Owner
    184
    King George, VA
    This is for the '07 TCH, but I believe it would work the same way on your car:
    1. The "POWER" switch must be turned off.
    2. The unlocking operation has two modes. To change the mode, within 1 meter (~3 ft) of the vehicle, on the FOB, press LOCK switch AND and the: trunk opener; unlock; or alarm buttons at the same time and keep held for at least five seconds. (Suggest you don't use alarm button. Could make all types of noise if you make a mistake and press ALARM before the LOCK button.):p
    3. When the mode has been changed, the answer back alarm will sound: 2 beeps -- All doors will be unlocked. 3 beeps -- Only driver's door will open (if door unlocked with driver's side SKS). If Passenger door open w/ SKS, all doors will unlock.
    4. Repeat to change the selection.
    Data was gleaned from my Owner's Manual.
  10. Tideland Prius
    16,211
    I think it's the same in the Prius. I remember playing around with it and I used the lock and the panic button
  11. G0ldenchild562
  12. QuiGonJohn
    QuiGonJohn Junior Member
    79
    Davie, FL
    I just tried this with my 2009 Prius and got it to work, and I have Smart Key. But it was a little tricky. The 2 beeps or 3 beeps are actually pairs of beeps. So for 2 beeps it is actually beep beep pause beep beep. And 3 beeps is actually beep beep pause beep beep pause beep beep. You also have to wait a little while after you have released the keys on the FOB for it to set/register. At first I thought I had totally disabled the keyless unlocking, but then it started working right. Also, I had to use lock & panic, first attempts to use lock & unlock did not produce any beeps.
