Smart key working, but car not sensing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Atomhingst, Mar 2, 2012.
  1. Atomhingst
    Atomhingst New Member
    Norway
    So, just overnight, suddenly the car doesn't respond to my key fob. When I press the button on the fob the little red light lights up, so the battery works. I open the car by usin the oldschool physical key, and get in. The car refuses to start up, until I try to put the fob in its slot, and then it starts like normal. What could this be? I tried checking other threads, but they were all about the fob being out of battery or broken, which doesn't seem to be the case here, as I tried both my two fobs and neither work. Any ideas?
    It's a 2008, by the way.
    52,697
    :welcome: there's an on/off switch below the steering column, maybe you bumped it? or maybe the lite will work when the battery voltage is too low for the fob to work. or maybe your 12v is going bad.
    stips likes this.
  3. Atomhingst
    Norway
    Thanks for the suggestion, but that wasn't it. When I try to start the car with the key in my pocket it lights up on the dashboard this icon as if I didn't have the key. Then I pressed the on/off button and did the same thing, with no reaction whatsoever :-/
    As for the battery, it would be a bit strange if both my key fobs died the same very morning.
    About the 12v battery, how will I be able to tell? I'm pretty clueless about cars, I'm afraid.
    52,697
    there is a test you can do on the mfd. search for it on this forum, if you can't find it, someone will post a link. or you can have it tested at the dealer.
    Harold m. Brooks likes this.
  5. Patrick Wong
    18,210
    6,517
    Although you may depress a fob button and see the red status LED appear, that does not necessarily mean that the fob battery has sufficient power so that the Smart system will work reliably.
    Your car is ~4 years old, and if the fob batteries are original, I suggest you replace them now to rule that simple and inexpensive issue out - unless you prefer to look for an expensive and complicated reason for your car's problem.
  6. cnschult
    cnschult Active Member
    772
    97
    Michigan
    wait a minute Patrick, are you saying that when you hear hooves you think horses are nearby, not zebras?? that's just crazy talk:D
    DashingDave likes this.
  7. Atomhingst
    Norway
    Yeah good point, I'll try that, I just thought it would be weird that both the key fobs died at the very same night. Especially since one has been in use and the other has stayed in a drawer.
  8. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
  9. ETP
    2,804
    1,170
    Auburdale FL
  10. bisco
    52,697
    if it is the fob batteries, it could be that the one in the drawer was already dead and so it seemed to you that they both died at the same time.
  11. tdelker
    tdelker Junior Member
    46
    Colorado
    Did you try this:
    I just had the same problem after bumping this small button down by the bottom of the dash under the steering wheel but closer to the pedals. I actually had to look in the manual *gasp* to find out why my smart key wasn't working.
    Tom
    stips likes this.
  12. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    The batteries in both of the smartkeys for my 07 failed at almost the same time at the age of about 4 3/4 years. I replaced them and everything was fine again. Then shortly after that I replaced the whole car.
  13. Chynith
    Chynith New Member
    Cambodia
    I also have problem same.
    My fob was replace new battery but still not work.
  14. bisco
    52,697
    try the other suggestions listed above, and welcome to priuschat.
  15. Chynith
    Chynith New Member
    Cambodia
    Hi Bisco,
    I try with above suggestion, but still not yet work... I replace 2 batteries, I check and push and unpush the cancel switch under steering but still not working..
    Any suggest else? also how to sync fob to smart key system?
  16. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Do you have another fob? If not, you should get one anyways because if you lose (or if it really breaks), it will get very expensive.
