Smart people make you smarter...
Discussion in 'Newbie Forum' started by douglasjre, Aug 27, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Smart people make you smarter and dumb people make you dumber. One user in particular selects who can see his profile and thus I cannot ignore him. This is the message I get: "
    PriusChat - Error
    This member limits who may view their full profile."
    How do I block that person, and others who have this setting if the ignore button is not available?
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Yep, I have the exact same problem!
    @Danny needs to understand... and hopefully @Tideland Prius will remind him that if they don't give us a way to "ignore" users due to this crappy "privacy" loophole, eventually there's going to be some kind of harassment lawsuit/expensive lawyers that they could of shielded themselves from before it became an issue.
    Basically, anyone who intentionally wants to target and harass a vulnerable Priuschat user can do so quite easily simply by making their profile "private" so there's no way to exclude/block/ignore their comments. THAT'S SO INCREDIBLY WRONG!!!
  3. ChapmanF
    19,042
    I haven't tried this, but maybe go to the profile of somebody else, hover over the button for blocking them, see if there is a visible URL associated, and see if that contains something like the member ID of that person. Then try to visit a URL constructed like that but with the member ID of the person you want to block, and see what happens.
  4. PriusCamper
    13,470
    5,438
    The problem is that the privacy settings block access to the upper right corner of a user profile if they select "private." So you lose access to the three links in that block, which I grabbed from your profile as an example:
    And clearly if someone wants to be private on their profile they shouldn't have the "Follow" link... But not being able to have a "Report" or "Ignore" link on a private profile is a recipe for eventual disaster and not related to us thick-skinned regulars on Priuschat but more for creepy stalkers and their victims with car repair issues. It's a significant security concern IMHO.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Not sure if this is any moderator's fault. Sure sounds like a forum software defect....
    REVVL V+ 5G ?
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Still, you wouldn't be completely without recourse. If you report the specific posts that are harassing a user, the moderator could take measures to stop it. It does put you at the mercy of the moderator's abilities and willingness to take action, but it's not nothing.
    Still, I agree that any user should be able to ignore any other user. But that's a forum software issue unless there's a setting in the control panel that can toggle an ignore button somewhere other than the profile page. I'm sure, if it exists, it's an administrator setting and not available to a moderator.
  7. douglasjre
    2,250
    751
    Null, NL
    Didn't work. I'm going send msg to admin re this
  8. Mendel Leisk
    42,364
    I think it's possible, to ignore someone hiding their profile. Not sure, but try this:
    Make a note of person's online name
    Mouse-over your avatar at top of page, right side. Click on "People You Ignore"
    Scroll to bottom, you'll see this:
  9. fuzzy1
    10,720
    I tried Chapman's proposal. It worked for me, and the re-built thread in questions shows this at the bottom:
    P.S. Mendel's suggestion also works, with less effort.
    #9 fuzzy1, Aug 28, 2022
  10. PriusCamper
    13,470
    5,438
    Thanks Mendel... That looks like a solid work around... Haven't tried it yet, because I need someone with a private profile to test it on? Anyone got a name of a user with a private profile?
  11. ChapmanF
    19,042
    douglasjre's profile seems to be private. I just tried my build-a-URL idea on it and it worked. It ended up showing me a "limits viewing profile" error afterward (because that user's profile is where the 'ignore' URL tries to leave you after it adds the ignore entry). But it had successfully added the ignore entry first, which I could confirm by following Mendel's idea and going to my own 'people you ignore' page. The added entry was there.
    Just adding it Mendel's way is still easier, of course.
    fuzzy1 and PriusCamper like this.
  12. Mendel Leisk
    42,364
    I was gonna volunteer, make my profile private temporarily, but could not figure out how to do that. Maybe untick everything in privacy??
    douglasjre likes this.
  13. douglasjre
    2,250
    751
    Null, NL
    Mendel and Chapman thank you so much that worked
  14. PriusCamper
    13,470
    5,438
    That's because god won't let you make your profile private!
  15. douglasjre
    2,250
    751
    Null, NL
    Mendel, used your trick once again. Works so well. This site looks mostly blank to me now lmao
  16. ChapmanF
    19,042
    jinx
  17. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    May I suggest just going somewhere else?
    Toyota Prius Forums
    iPhone ?
  18. markismail
    markismail Junior Member
    amesterdam
  19. McCarthy
    McCarthy Junior Member
    94
    85
    When you get to this stage, its time to get away from the online world.
    Is that Sebring or Jennings?
  20. douglasjre
    2,250
    751
    Null, NL
    Roebling I think. Sebring is car only. Used to race CCS SE Circuit
    McCarthy likes this.
