Smart plug for the prius prime
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, May 13, 2019.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I find the charging scheduling system that come with the prime is not great. I was wondering if anyone knows of a smart plug i could use to charge the prime. I tried one and it blew out and stopped working. Are there any high voltage/ amp smart plugs.
    I would like to control from my phone because I am worried of blowing out my wall socket so I unplug it when I'm not using it and it's very inconvenient unplugging it and plugging it back it at the wall.
    Any solutions
  2. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Won't the Toyota entune app meet your needs?
  3. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    That's only for the advanced model, he has a plus. I wish I had it for my premium. :(
  4. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    I use a TP-link Kasa one which is capable for 15A.
    EyePrime likes this.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  6. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    This may work. It also has an app.
  7. Tideland Prius
    16,680
    No Entune in Canada for the 2017-2019 Prime.
    It bugs me that I can’t control my charger either via an app.
  8. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    Maybe the simple solution is to use a dedicated 120v 20amp circuit per the car's requirements. If the circuit you are using has other draws, try to unplug them or simply change your Prime to the 8amp charge setting so as to not cause a problem with the breaker or your outlet.
    #8 pineprius, May 14, 2019
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Near as I can tell there is no way to set a charging schedule with Entune. I can check the state of charge and time estimate until fully charged. I can set the temp and front/rear window defrosters. That's all folks.
  10. EyePrime
    268
    115
    2018 Prius Prime
  11. pineprius
    245
    134
    NC
    Page 122 of the manual states:
    ● Connect to an AC 120 V outlet (NEMA 5-15R) with a Ground-Fault Circuit-Interrupter (GFCI) and a circuit breaker. Use of a 15A individual circuit is strongly recommended to ensure charging cable will operate properly.
    Make sure you don't have other demands on this dedicated circuit. I have found if this cannot be done for lots of other reasons, lowering the Prime car charger (in settings) to 8amps works just fine. We charge overnight and sometime "charge now", but do not have an issue.
  12. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Actually you can adjust the schedule from the app. You have to click this tiny button:
    Then this screen appears where you can change the schedule:
