Smartkey Seed/Passcode calculation service
Discussion in 'Knowledge Base Articles Discussion' started by 3prongpaul, Sep 29, 2011.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    731
    Boulder Hybids, Boulder, CO
    You may have read that it is impossible to mate a used Smartkey fob (i.e. "Ebay fob") with your Prius and have full Smart Key functionality unless you take it to the dealer or locksmith.
    If you have access to Techstream software along with an appropriate interface like the $500 Mongoose MFC cable, you can do it yourself by paying an online service to calculate the one-time passcode from the seed that Techstream supplies.
    Calculation of Passcode for Toyota, Lexus, Scion vehicles - Service
    The place is in Europe (Lithuania). They charge 20 Euros for each
    passcode calculated (around $28) They are open USA morning business hours and do it via PayPal/email within a few minutes. Easy peasy if you only need to do it once in a while.
    If you have to calculate seeds regularly, (i.e. you're a locksmith) they will sell you the software for 800 Euros which works on many makes and models of cars.
    3 people like this.
  2. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Here is a cheap calculator for the one want to do business from that...its only for 375$ working and tested
    eBay link
    52,409
  4. Esodprius
    Esodprius New Member
    I just lost my only original fob key(no spare keys) for my 2005 prius and just received the bought new 2 fob keys and a manual key from Amazon plus the mini techstream vci which I have zero knowledge what it is and all new to me . Is the passcode access the last thing I need to brave and start programming these bought fob keys or is it easier to bring to Prius shop I called and can do all these for $150 (after I get my car towed to his shop). Thank you all for any detailed instructions I may need from here.
  5. 3prongpaul
    956
    731
    SFO likes this.
  6. Esodprius
    Thank you for the response ! I went with the easiest route and have the expert , Mr. Andre do the fob key, that he brought with him, get programmed ! He came and spent 30 minutes with the computer to get my Prius back to its drive. I will keep the link for future reference .
  7. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I bought the new seed and watched the video on how to get the passcode. My question for you is what next? What do I do with the passcode? How do I program the second key now?
    Note: My techstream doesn’t have a “utility” button
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    You won't see "Utility" until you go into the correct computer section.
    Hopefully whatever video you are using shows you the full procedure.
  9. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I’m being told I will need to upgrade to a better mvci cable. I am trying to program a used fob with a new purchased passcode but I have no utility button to begin the process
  10. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    From the main System Selection Screen you should have a list of modules all highlighted in yellow.
    Post a pic of that.
    I think the correct section is called something like Smart Key. I don't remember exactly. I'm doing this from memory.
    Again, post a pic.
  11. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I will post in the next 10 mins.
  12. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Maybe the section is called Immobiliser?
    When you are on the main screen you should be able to go over each section and see a description of it in the box below the menu.
  13. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I have entered the immobilizer screen and still no utility button.
  14. Figster10
    Figster10 Member
    207
    61
    Sacramento
    This is what I get when I enter smart key and inmobilizer. I notice other videos being able to have this “utility” button to begin adding a key but I am unable to have it on here on the left
  15. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Does your software connect to the car so you can see live data?
    Have you used this for other diagnostic on the Prius?
  16. Figster10
    Figster10 Member
    207
    61
    Sacramento
    This is a cable test that showed fails for SIL and a programming link for both pins as shown here. My guess is I need to upgrade to a better cable, right?
  17. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Get an older version of Techstream ;).
    V10.30.028 works well for us as we had a much newer version (version 13.xx. 024) and it didn’t have the same functionality :cool:.
    Something else to try and see if that helps(y).
    Figster10 and SFO like this.
  18. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Yes sir
    Raytheeagle likes this.
  19. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    With version 10.30.028 I’ve paired several keys to Gen3’s, paired TPMS sensors ,etc.;).
    Good luck and keep us posted (y).
  20. Figster10
    Figster10 Member
    207
    61
    Sacramento
    That’s the other thing I noticed over the weekend how I couldn’t pair the TPMS sensors either. Clearly I’m off by a mark or something but will do what you told of me this late evening.
