Smell of gas coming out air vents on 07 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cibelly Aguiar, Jan 16, 2018.
  1. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Do you mean recirculate mode?
    Range? Do you mean average? If you do, how many miles did you do to get that average?
    Might think about a different mechanic, if he doesn't torque down spark plugs.
    51,972
    when did you last get an inspection sticker?
  3. Patrick Wong
    18,210
    6,510
    1. If your exhaust system had sufficiently deteriorated so that there were holes in it, then I suggest you need to replace the entire exhaust system including the catalytic converter. You may still be smelling engine exhaust, for example leaking from a broken gasket between the exhaust manifold and the exhaust pipe, or a small hole in the exhaust, etc.
    2. A gas smell accompanied by abnormally low fuel economy would imply you have a leak somewhere.
    3. Since you don't know the prior maintenance history, I think you should replace the iridium spark plugs, make sure the new iridium plugs are the correct NGK or Denso brand, and tightened to 13 ft.-lb.
    At 173K miles on the odometer, and considering the corrosion that you reported, it is reasonable that you need to put some money into Prius maintenance.
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    @Prius_Cub here in Virginia had they exhaust manifold rust out probably due to road salt during winter. But he had a noise under the hood. I am confused if we are talking about an exhaust smell or a gasoline smell.
  5. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    Here is one of the threads I found when I was trying to figure out my issue. I had thought for sure I had some sort of fuel/exhaust leak that was coming through the fresh air vent, so I'd only smell it at low speeds. I even bought and was going to put in all new Fuel Injector seals as I thought I could smell it in that area. Turned out once the spark plugs were taken out again and put back in using the torque specs per the manual, the smell is gone.
    Smell of gas thru vents. Also smell it outside car when off... | PriusChat
    bisco and Raytheeagle like this.
  6. bisco
    51,972
    but the mechanic said there's no such thing as spark plugs not torqued down properly.:whistle:
    gta_ and Raytheeagle like this.
  7. Cibelly Aguiar
    Cibelly Aguiar Junior Member
    59
    Boston
    June, last year
  8. Cibelly Aguiar
    59
    Boston
    Yes, I'll be taking to another one tomorrow
  9. Cibelly Aguiar
    59
    Boston
    I'm afraid of that too because here in Massachusetts we had a rough winter... It's kind both smells, now it smells less like gas and more like exhaust smell. A smell that like burns inside the nose, and when I turn on the recirculate mode on the A/C, it stops.
  10. Cibelly Aguiar
    59
    Boston
    That was the quote I got from a Toyota dealer here...
  11. bisco
    51,972
    i wouldn't replace the cc until it fails the next inspection.
  12. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    if the cat was bad it would turn on the check engine light. change and torque spark plugs. get a good flashlight and look the motor over carefully from the top and bottom for any signs of fluid leaks. if the exhaust is leaking you will hear it, and you might see black soot marks at the leak the condensation water you sometimes see is normal. if your only getting 20 mpg, something is very wrong with your car. find an honest competent technician asap.
  13. Cibelly Aguiar
    59
    Boston
    Okay, some updates...
    I took the car to my regular mechanic on Friday, he saw a bit of grease under the car and assumed that the smell was coming from that because the grease was getting hot, so he cleaned it. The smell is still there. He checked the spark plugs and said that by the end of April I need to change my oil, so he'll change the oil and the spark plugs because he said they need to be changed.
    Yesterday, Saturday, as I had an appointment with a mechanic friend of some friends, I took the Prius there and gave a superficial look, but found that (I don't know the exact name) exhaust pipe is kinda loose, because he was like shaking the pipe and it was making noises. He told me to go back on Thursday so he can take a look...
  14. Cibelly Aguiar
    59
    Boston
    Okay, the engine light... Last year, since when I got the car all the lights were on, like engine lights and maintenance lights. I told my brother that and he took the car somewhere and they found out that the exhaust system, somewhere, had like holes, so the car was very noisy. So they fixed it and cleaned the lights on the dash. Do you think that if the cat were bad the light would turn on again?
  15. Cibelly Aguiar
    59
    Boston
    By the way, some people recommended me yesterday to use something in the car called Lucas for fuel treatment. I don't know if it will make any good, but well...
  16. Cibelly Aguiar
    59
    Boston
    I followed your advice. Yesterday, my dad and I replaced the old spark plugs for some new Denso ones. It turned out to be that one of the plugs was not torqued down properly, so loose that we thought that the things that hold them could be broken, but thankfully it wasn't. I even took a picture of how the plug looked.
    And, overall, I didn't notice the smell anymore and the car seems to be somewhat faster when accelerating. The only thing I'm still evaluating is the fuel economy. My car was doing around 25mpg, and a total of 180 miles with a full tank, now it seems to be more economic too. So, thank you again for your input, it was very helpful!!!
    tangerino, gta_ and Raytheeagle like this.
  17. First_Time_prius_owner
    First_Time_prius_owner Junior Member
    28
    23
    toronto
    I am having a very similar issue now. faint gas smell. my mechanic looked at the car, replaced the fuel injector seals for $250 and the smell i smore faint but still there. i am worried that it is getting worse. i only smell it when the car moves slowly/ICE is on and the vents are bringing in fresh air. this leads me to believe it could be 1. spark plugs (i havent changed these since i got the car a year ago) 2. fuel injectors 3. gas line in engine bay? where is that btw? any othr ideas? i am going to work ont he car this weekend...
