Smoke Alarm Battery Dies: Throw it out?
Discussion in 'Environmental Discussion' started by hill, Sep 30, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,080
    Northern Michigan
    She only smokes when she drinks.
    Tom
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Wow, you might be my long-lost illigetimate brother
    :pound:
    Of course, that is what most females do
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    Can I come stay with you after my unemployment benefits run out, brother? I'd like to take up whittling. :madgrin:
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    If you cook, clean, and keep an eye on the house while I'm away at work .... I might think about it
    But no frilly French Maid outfits, or Man Boobs either. I'm not a prude, but that is where I draw the line
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    Looks like I'll be out on the street then. The GF already expects me to do cooking and cleaning, but I'm not really that happy as a domestic servant.
    I do have a household tip though:
    Folding Fitted Sheets
    1. Wait until your spouse/partner/friend with benefits has left the house. This will allow you to concentrate on the task with undivided attention.
    2. Fold pillowcases first, then the top (flat) sheet and then finally the bottom (fitted) sheet. This allows you to fold the easier sheets first and build confidence.
    3. After folding and neatly stacking the pillowcases and top sheet, pick up the bottom sheet and find the seam in each corner. Place your hand inside the corner and match the corners to each other until you have all four corners gathered together.
    4. Wad the whole thing up into a ball and shove it into the back part of the closet where it won't be obvious. Stack the top sheet on top to keep your spouse from finding it. Go about your day.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Um ... you have to *fold* fitted sheets before you put them away???
    I guess that's why mine are so wrinkly ...
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, I have even seen it demonstrated a couple of times. But I cannot replicate the results. It ends up a wad of sheet no matter how I do it.
    There are people who can do this; otherwise when you bought a new set of sheets, they would come in a wad in the package. :madgrin:
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    I figure if fitted sheets had to be neatly folded after coming out of the dryer, they would just fold themselves
  9. qbee42
    18,058
    3,080
    Northern Michigan
    Better to have fitted sheets than shitted feets.
    Tom
  10. dogfriend
    7,512
    1,190
    Carmichael, CA
    Can't argue with that. Don't think I would want to fold shitted feets either.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I have a funny story along those lines ...
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    Go on. Does it involve sheep? :madgrin:
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Now that you mention it ...
  14. qbee42
    18,058
    3,080
    Northern Michigan
    As long as they are adult consenting sheep.
    Tom
  15. dogfriend
    7,512
    1,190
    Carmichael, CA
    Baa means no? Or is it yes? How can I tell? :madgrin:
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    It's very complicated. Just assume yes
  17. dogfriend
    7,512
    1,190
    Carmichael, CA
    It would be baaaaad to be wrong about this. :madgrin:
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    I agree, very baaaaaaaaaaaaaad
