Smoke and burning smell from dash
Discussion in 'Gen 3 Prius Technical Discussion' started by Anil kumar, Apr 20, 2019.
  1. Anil kumar
    Anil kumar Junior Member
    United kingdom birmingham
    HI guys just opened the car to get something out interior lights came on and then went dim after a few seconds there was a burning smell and smoke coming from pedal area currently waiting for AA check it out all light in the car are led bulbs and the fuse has not blown AA patrol came out to check so if we insert 10 amp fuse for dome lights smoke starts to come from dash area behind steering wheel if we remove the fuse smoke stops
  2. Anil kumar
    Another problem now the car thinks the doors are open and wont lock and when you put it in to drive it says shift to park
    52,694
    doesn't sound safe. you're going to have to open things up and find the short. don't let a car fire spoil your day!
    Montgomery and jerrymildred like this.
  4. Anil kumar
    Car is not bieing used until sorted i need to get an auto electrition to have a look at it
    Montgomery and Robert Holt like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Automotive electrics can be a bear to troubleshoot sometimes since the wires are often hidden. There's definitely a short in there somewhere, though. You might be able to spot a charred place.
  6. Anil kumar
    Fixed the problem door pudel light led were shorting out in the holder sorted out now also put a 7.5 amp fuse instead of a 10 amp
    kc5dlo likes this.
  7. Mendel Leisk
    42,193
    Were some spray cleaners recently used? Or some new accessory plugged in?
