Smoke on the waters
Discussion in 'Tesla' started by bwilson4web, Jun 29, 2019.
  1. bwilson4web
    16,552
    Source: Tesla vehicle fire in Shanghai caused by single battery module – TechCrunch
    The Tesla Model S vehicle fire that occurred in Shanghai this past April, prompting international media attention, was caused by a single battery module and is not a system defect, the company said Friday.
    Tesla provided the update on the cause of the fire in a post Friday on its Weibo social media account. A team of investigators analyzed the battery, vehicle history, software and manufacturing data. The fire was caused by a single battery module at the front of the vehicle, Tesla said.
    The company has issued a software update that will change battery charge and thermal management settings in Model S sedans and Model X SUVs.
  2. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Huh.. I seem to remember when the original roadster came out they were saying how much engineering went into the battery so that a single bad module would be contained and not cause a runaway fire. Oops?
    52,894
    i think we need more info on what the fix actually does
  4. Trollbait
    12,832
    Design and manufacturing mistakes happen. Ford had to recall thousands of cars because the wiring harness in the steering wheel was causing fires. For Honda, it was a window switch. They aren't the only manufacturers to have had cars start burning while parked from some type of defect in a common part.
  5. bwilson4web
    16,552
    There are reports that Model S and X are experiencing slower, fast DC charging.
  6. bisco
    52,894
    too bad, if true
  7. DMC-5180
    DMC-5180 Active Member
    294
    134
    They also use the 18650 cells vs the newer 2170 cells in the model 3.
  8. tpenny67
    464
    403
    Massachusetts, USA
    Ford is the global leader in vehicles catching fire. There was the Pinto. My generation Mustang has the same fuel tank location as a Pinto and for extra effect the doors are known to jam shut in a rear end collision. Brake fluid can leak into the cruise control cancel switch and start a fire in many F150s. For reasons I can't fathom that switch is powered when the vehicle is off so people have burned to death sleeping in their bed when their truck catches fire in the garage.
    I hadn't heard about the writing problem you mention but it doesn't surprise me. Tesla has a long way to go if it wants to catch up with Ford in vehicle fires
  9. Trollbait
    12,832
    Tesla has a long way to go to catch up with anybody in vehicle fires.
    el Crucero likes this.
  10. hill
    9,041
    new data proved the parameters for potential problems needed to be widened? ... update covets the new parameters?
