Snapped off threaded stud that holds lug nut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stevewoods, Aug 6, 2017.
  1. Patrick Wong
    18,210
    6,517
    What was your method to remove the broken stud?
    It appears your method to install the new stud was to use a washer and a lug nut to pull the new stud into the hub hole.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,243
    Orange County, CA
    That is correct. I raised up the car, I removed brake caliper housing (you can use wire, rope or bungey cord to suspend caliper). Make sure to either keep your driver side door closed during this process or, disconnect the battery. The Prius pressurizes the calibers when you open the drivers door and if you have the caliper off of the disc.....................Yep, cancel Christmas.
    I just tapped the broken bolt out. I used the socket to "pull" the new stud through using the lug nut. I don't remember where in this site I posted my process, but it was a complete success. Took under 15 minutes. You have to remove the brake caliber housing otherwise you cannot reach the bolt. Good luck.
  3. ChapmanF
    19,025
    Never occurred to me before, but I bet an enterprising sort could straight-up use the brake caliper after unbolting it (along with a couple nearby junk-drawer bits) to press the stud out. Instant roadside repair....
    -Chap
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    That would be a great MacGyver moment!
  5. Georgios
    Georgios Member
    126
    85
    Chicago
    It happened to me and here is my way of doing it.
