Snow tire size
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriusGuy32, Feb 13, 2015.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    So I have a set of Michelin X-Ice 185-65-15 that are leftover from my 2007 Prius that I just traded in...I didnt realize the tires on the Gen3's are a different size :mad:
    My 2012 Prius tire size is 195-65-15. Can I get away with using the 185-65-15's with no harm to my new car?
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It'll ride lower and the speedometer will be off....and it'll look funny.
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The sidewall height on the 195's is 126.75mm and on the 185's it is 120.25mm... That's like the difference between new tires and balding tires, I wouldn't worry about it.
  4. tv4fish
    tv4fish Member
    202
    46
    I agree that it should NOT be a big problem. I had a set of snow tires with their own wheels on my 2005 Prius (front only) and when I sold that and bought a 2010 Prius, I kept the snow tires/wheels. This is the second Winter on the 2010 with the 2005 wheels/tires on the front and no problems at all.
  5. B24Liberator
    B24Liberator Junior Member
    Ohio
    I put my Nokian Hakkapeliitta RSi snow tires (mounted on steel wheels) from my 2004 Prius on my new (April) 2014 Prius four. This was the first winter for my 2014 Prius and the snow tires have worked fine all winter. The only problem is that I have to put up with the low tire pressure light on the dashboard since I didn't bother buying the tire pressure gauges for these tire.
  6. Mendel Leisk
    42,211
    How much tread is left on your old snow tires? Maybe time to break out the credit card? ;)
    Strange though, this time of year I'm wondering why the hell I'm running on snows, here on the wet coast.
  7. B24Liberator
    Ohio
    I bought the tires Jan 2007. I only put about 4000 miles per year on them. Each tire has numbers imbedded in the them 8-6-4-2. When the number 4 wears away the tires should be replaced. At this point the 6 is visible on two tires and the 4 is visible on the other two. So I'll see how they wear and then decide 2016 or 2017.
