Snow tires or what?
Discussion in 'Gen 2 Prius Main Forum' started by canesfan, Dec 1, 2010.
  1. canesfan
    canesfan Culture shocked...
    544
    Jacksonville, NC
    OK, here I am, the OP. Basically, it has come down to this. We are probably getting the Toyo Observes from Les Schwab, or they may be able to get us the Nokian Hakkapeliita (R or Rsi, not sure?). So, we will have to decide between those two. Now, we have to decide whether to have them mounted on our Prius wheels, or they say they have some (not sure what kind) they can sell us so we don't have to keep re-mounting every year. Hope I'm making sense, I'm not real up on the whole tire/wheel terminology. Thoughts, anyone?
  2. Optimus
    Optimus Member
    274
    25
    As long as you can afford it, I would recommend getting the second set of wheels. It is what I do. As you mentioned, there are extra costs incurred if you have two sets of tires and only one set of wheels having to swap them around every fall/spring. There's always risk of damaging a tire while mounting/demounting too. I wouldn't say it's a great risk, but if the person doing the work is careless, it doesn't take much effort to rip a chunk out of the bead on the tire and suddenly you have to get a new tire. If you are able to swap tires/wheels yourself in the spring/fall, then you can do it on your own time and not have to pay a shop to it.
    If you go with the common black aftermarket steel wheels, you may also want to consider getting some hub caps (unless you like the look of standard black wheels). If your new set of wheels are aluminum, then you won't need to worry about that. Either way, you'll probably need new lug nuts too as the Toyota lug nuts are specific to OEM wheels only.
    We use (LOTS of) salt on our roads here, so what I actually ended up doing is mounting the new snow tires on the stock Prius wheels (I don't care much for the stock wheel's look anyway). I bought new alloy wheels for the "summer" tires. I figured if I'm going to spend money on wheels, I might as well put it into ones that won't see the effects of road salt.
  3. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    I also second the notion to get new wheels. They will pay for themselves in a few seasons vs paying to have them remounted.
    I had the Toyo's on my Subaru (which are awd). I can't speak for the traction in terms of acceleration, but stopping and turning were GREAT. I would highly recommend them. In fact, the only reason I still don't have them is I ended up with a new Subaru and they wouldn't fit, other wise I'd still have them.
    On the Prius we run Gislaved tires, these are amazing, I live up a 2 mile long hill and have had NO problem climbing it in the snow, even when I had to stop and start again.
    I would also suggest the Nokian's, they are also an amazing tire.
    You WILL notice the differance with the proper tire on the car.
    PS, don't waste the money on a aluminum rim for the winter. The salt will eat at it anyway so just go with a black steel wheel. They'll be white with salt anyways. Unless you want to go the route like the above poster which is using the stock wheel and buying nicer ones for the summer.
  4. Mendel Leisk
    42,254
    There's likely a Toyota 15" Corolla steel rim that will work for you. Check with Toyota parts/service.
  5. canesfan
    544
    Jacksonville, NC
    OK, let me clarify that I have a Touring so I would need 16" wheels. Also, no salt on the roads in good ol' Oregon. Not environmentally friendly, you know. ;)
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Alloy wheels aren't intended for frequent remounting. If you switch back and forth between summer and winter tires, you will quickly find yourself buying new alloy wheels - might as well put the money into steel winter rims now and avoid the problem entirely.
    Tom
  7. Patrick Wong
    18,210
    6,517
    Since you intend to buy a new set of wheels, I suggest that you buy 15" wheels which allows you to fit 185/65R15 winter tires. This provides you a greater selection of tires at lower prices. Also, the narrower 15" tires will give you better snow traction.
  8. a_gray_prius
    2,927
    783
    IL
    Get the Nokians. Seriously. I have a second set of rims for summer use. Here's an option: Get them mounted on your stock wheels now, and buy a second set of stock rims off someone before you have to switch over to summer tires.
  9. canesfan
    544
    Jacksonville, NC
    Where would I get some 15" Prius wheels, besides a dealer? I know I'm going to take a mileage hit with studless winter tires, and even more of a hit with steel wheels. Wouldn't it be best to try and get some Prius 15" wheels?
  10. Patrick Wong
    18,210
    6,517
    It sounds like you plan to buy from Les Schwab so you can ask what 15" steel wheels they can fit to your car. As an alternative, since you want to buy both wheels and tires you may find that Tirerack.com will offer an attractive package that will meet your needs. The tires will be mounted and balanced so you'll just have to install them when your roads turn snowy.
    Regarding mpg hit for steel vs aluminum, I personally would not be concerned about that, considering the cost difference on the wheels.
  11. Mendel Leisk
    42,254
    We've got 2010 Touring, purchased in Canada, comes stock with 215/45R17 on alloys, but went with 15" black steel Toyota Corolla rims (p/n: 42611-02471) and 195/65R15 snow tires. The OD of that 15" tire is actually slightly greater than stock.
    Also needed different nuts for the steel rims. Didn't get the Tire Pressure Monitors, which just means a little warning light goes on on the dash.
    The parts department of dealership we purchased from was adamant that Prius alloys were the only solution, either 15" or 17". In desperation I carpet emailed every dealership in town, and one came through with the suggestion of Corolla rims. Worked out fine.
  12. Optimus
    Optimus Member
    274
    25
    Can you elaborate on this?
  13. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Yep works fine!
    I run Corolla steel wheels on our 06 for the winter.
    Basically he means that your chances of damaging a wheel are higher because of the machine/person that takes the tire off.
    You are also breaking the bead on the tire (that holds it to the wheel) everytime you change the tire, so eventually that bead can fail because the tire is really only ment to be taken off of the wheel when the tires life is done...not every 6 months.
    Really, for what it costs to swap tires 2 times a year you can buy a set of wheels and make that cost back up in a short amount of time.
    If you have the means, you can also change your wheels yourself rather then paying someone to do it.
  14. Optimus
    Optimus Member
    274
    25
    How does this affect alloy vs. steel?
  15. qbee42
    18,058
    3,081
    Northern Michigan
    Prius 06 did a good job with his explanation. I will add just a bit more: Alloy rims are softer than steel, and tend to suffer more mechanical damage from the process of breaking beads and mounting. Also, while alloy rims don't rust, they do suffer from corrosion. Scratches introduced from mounting provide a starting point for corrosion around the beads. Once this happens, small leaks develop. While the bead area can be resurfaced, each iteration takes a little more material off of the rim.
    In short, alloy rims were designed for weight and beauty, not ultimate durability.
    Tom
  16. Optimus
    Optimus Member
    274
    25
    I should probably mention I worked in a tire shop for several years and have my own tire machine (and balancer).
  17. canesfan
    544
    Jacksonville, NC
    Excuse my ignorance, but what is "OD"?
  18. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    "Filoform corrosion"
    Almost all automotive alloy wheels have a clear coat layer.
    It's well known that alloy rims are softer than steel rims, and can suffer from frequent tire mounting. Some of the newest fanciest machines do a good job
    TCX575 Tire Changer
    But it really depends on the skill - and care or lack thereof - of the operator. It has been my experience that most tire shop employees do not give one rats nice person and I have badly scratched alloy rims to prove it
    With winter salt, i prefer steel rims anyway. I can spray both sides of the rim with Fluid Film before mounting and don't have rust issues
    Around here if used all year round once aluminum rims are +6 years old they look pretty bad
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Outside Diameter or how tall the tire is
    Eg for my FJ Cruiser it came with P265 70 17 tires from the factory, about 31.7 inches OD
    The correct "minus size" is P265 75 16 as it also has an OD of 31.7 inches
    I can't go smaller due to the brake rotors
  20. canesfan
    544
    Jacksonville, NC
    Is there any benefit to getting 15" Corolla rims vs. the generic 15" rims from the tire place?
