So I asked Autoline TV about diesels
Discussion in 'Diesels' started by bwilson4web, Aug 18, 2017.
  1. bwilson4web
    16,544
    My question to Autoline after hours at 48:10:
    • 17 hours per year - average time spent looking for a parking spot per year
    • low expectations for Equanox
    • diesels have a pending emissions problem, expensive
    • diesel and gas gap is closing
    • plug-in hybrid called "the sweet spot"
  2. wxman
    wxman Active Member
    636
    231
    Tennessee
    I watched 10-15 minutes after your question was presented, Bob.
    They make some good points, but I disagree with a few (that I saw):
    - the expense of bringing LD diesel vehicles into compliance with Tier 3/LEV 3 is already "baked into the cake." All LD diesel vehicles currently on the market in the U.S. have SCR for NOx emission control. It can be very effective as demonstrated by CARB itself (2015 VW TDIs "after repair" have NOx emissions near SULEV levels, according to a graphic on their web page).
    Also, many if not all direct-injection gasoline vehicles (GDI) will probably require particle filters (GPF), or should at least, when Tier 3/LEV 3 is full implemented. That will likely increase their cost at least somewhat and may even degrade mileage a little.
    - I'm not convinced the fuel efficiency gap between gas and diesel have been close as much as implied in that discussion. They cite the Equinox as not having a significant difference between the diesel and the 1.5 gas versions. However, the official overall difference between the diesel and gas versions of all vehicles in which both are available (2017 model year) is about 32% based on my calculation (hopefully correct). The often-stated advantage of diesel over gas is 30% and has been for a couple of decades now.
    Also, if you take the BMW 3-Series as an example, the gap between the diesel version (328d) and the nearest equivalent gas version (320i) is about 30% officially. In Fuelly, the "real-world" gap is almost 45%.
    I acknowledge that hybrids are generally better for urban driving, but diesels still can be advantageous for some driving conditions.
    #2 wxman, Aug 18, 2017
  3. Mendel Leisk
    42,356
    Are there problems making a diesel hybrid? Or is it just kind of pointless, no significant advantage?
  4. wxman
    wxman Active Member
    636
    231
    Tennessee
  5. bwilson4web
    16,544
    Interesting, I took a snapshot from the EPA web site but only to compare the '39 MPG' highway diesel, not all trims, to the Toyota RAV4 hybrid. So using the least efficient Equinox as the baseline standard:
    year model trim City Highway Combined %
    1 2017 RAV4 Hybrid AWD 2.5L 34 30 32 33.3%
    2 2018 Equinox Diesel AWD 1.6L 28 38 32 33.3%
    3 2018 Equinox Diesel FWD 1.6L 28 39 32 33.3%
    4 2018 Equinox Gas FWD 1.5L 26 32 28 16.7%
    5 2018 Equinox Gas AWD 1.5L 24 30 26 8.3%
    6 2018 Equinox Gas FWD 2.0L 22 29 25 4.2%
    7 2018 Equinox Gas AWD 2.0L 22 28 24 0%
    My BMW i3-REx uses a 660 cc, derated motorcycle engine to drive the generator for the range extension to get ~40 MPG @70 mph. Assuming a 33.3% efficiency increase, 40 MPG -> 53 MPG. But there are technical challenges when re-sizing a turbo-diesel and the emissions equipment.
    #5 bwilson4web, Aug 18, 2017
  6. wxman
    wxman Active Member
    636
    231
    Tennessee
    Thank you Bob.
    Have you looked at the "unrounded" adjusted fuel mileage ratings for the Equinox diesel (Download Fuel Economy Data - "2018 datafile")?
    The AWD diesel version actually has incrementally better combined fuel mileage than the front-wheel drive version (31.82 mpg for the AWD; 31.78 mpg for the FWD).
  7. wxman
    wxman Active Member
    636
    231
    Tennessee
    There was a two-cylinder, 730 cc two-cycle diesel engine being developed by Renault (Could Our Cars Get Two Stroke Diesels? - Engine Builder Magazine) for such applications. Renault claimed 50% efficiency (5th paragraph).
    Haven't heard any more about it since 2015 though.
  8. Trollbait
    12,831
    It's mostly about cost. Hard enough to get car buyers in America to consider a hybrid or diesel because of that higher price.
    Then the gas hybrids have good fuel efficiency because the ICE is a low power Atkinson version. The low torque of electric motors matches up to the ICE quite well. Diesels, on the other hand, are already good on the low end torque front. The cost of a full hybrid system won't bring as much gains to the diesel.
