So I bought an 07...
Discussion in 'Gen 2 Prius Main Forum' started by Newber, Jun 12, 2018.
  1. Newber
    Newber New Member
    So I bought an 07 with 132k on it. Great maintenance history and in decent condition. I think the car might have an issue, but I’m new to this. Looking for some help from the Prius fanatics here....
    So when I drive the car home I had to climb a fairly long overpass. I had the pedal to the floor and could only go 60mph.
    I also notice when playing music and driving with the AC on high recirculating cabin air, the battery on the display went down to one purple bar, then no bars when I climbed the hill.
    It seems I got almost 38 mpg on my drive home (all freeway).
    Just seems a little off like I should be getting a little better fuel mileage and power. Tell me the hybrid battery isn’t going out. Is it possible just a couple cells are bad? Wondering the cost to replace if so.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    1) Slow down!
    2) Look up "pulse and glide"
  3. Newber
    Newber New Member
    What’s that mean in English?
  4. kenoarto
    398
    Chicago, IL
    38MPG for 70 mph sounds about right. If you want higher MPG, slow down.
    Spend some time looking up some data and charts that show the MPG Prius will get at speeds between 0 and 70.
    If you want to get VERY high MPGs you need to learn how to "pulse and glide".
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    This is merely my experience, yours may vary:
    This is not a good sign. The only time a 2007 should max out at 60 mph is if it's towing another one behind it. The only time I ever had anything like that happen was when I bought a 2005 with a failed HV battery and drove it home. Took forever to get up to speed and absolutely HATED any kind of up slope, even fairly gentle ones.
    Was this during normal driving or after sitting idle for a while with the AC running? If you sit parked, running the AC, it will drain the battery down to 2 bars, then the engine starts to recharge it. Then the engine shuts off after and the AC drains it again. Over and over. If you happen to then start driving, the car will act like a dog until the battery has a chance to get up to 4 bars+. If you're driving and the battery goes to zero bars, there is something not right.
    I do between 70 and 85 on the highway portion of my daily commute. I have never been under 42 mpg. The only time I came close to 38 was a trip from Columbia to Atlanta when I hooked up with a few cars in the hammer lane and did 90+ pretty much 80% of the trip. Obviously, your traffic conditions may vary greatly from mine.
    It's difficult to diagnose through the internet, but as you say, it does sound like something is off. The 60mph thing is a big red flag to me. Even the mountains of Tennessee and West Virginia haven't caused that kind of heartache for me. It would be a good time to get a Bluetooth OBD adapter and some apps to monitor/test the car while driving. Techstream is your best bet for getting info from the car while not driving, unless you have someone drive while you play with the laptop.
    Raytheeagle and jerrymildred like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Was the AC on when climbing the overpass?
    • What temperature was the cabin setting for your drive?
    • How long of a drive did you have?
    • Did the previous owner mention how the car was driven, or if it sat for any period of time?
    • What part of the great state of California are you located?
    Fast cycling usually is a sign of a weakened battery pack and lack of power on inclines points to the same:(.
    Depending on your DIY acumen, there are solutions to this:).
    Good luck and keep us posted (y).
  7. Newber
    Newber New Member
    Ac was like 65 mid way puking outside air
    3 hour drive
    Car sat for months I think not used a lot before I bought it and they didn’t drive it hard
    SoCal
    What can I do if I have a battery going out other than drop 3k on a new battery?
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    What @TMR-JWAP said. You'll need to verify it with Techstream, but it sounds like the traction battery is on its last leg. If 60 mph going up a hill was the limit for the Prius, you wouldn't be seeing them everywhere you look.
    As to if it's just a couple cells, that is probably the case right now. Again, you'll need good scanning tools to know which one or ones. But once one fails, the others aren't far behind.
  9. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Jerry,
    You are correct that all of the modules age but your experience is in a hot climate where the major cause of aging is heat. In northern climes heat is less of a problem and many traction batteries get in trouble just due to cell imbalance as they get older. In those cases the individual modules still have some life left. Only those that have had a cell reversal (due to imbalance) need replacement with modules with similar capacity and the whole HV battery needs to be carefully rebalanced.
    So your strong suggestion to get a full set of new modules is good advice in hot climates, but DIY module replacement, although a time consuming process requiring a significant learning process, is viable when the HV battery has lived in a cooler climate.
    JeffD
    Raytheeagle likes this.
  10. Newber
    Newber New Member
    I just got off the phone with a couple local shops.
    One guy said if your car hasn’t thrown any codes or warnings, the battery isn’t the problem. He also said getting 38 mpg with the ac on for the miles on the car isn’t bad.
    Spoke to another guy that said it sounds like a motor problem only getting to 60 mpg uphill. Asked about oil type and to find out if catalytic converter was ever changed. Also said to wipe exhaust pipe for oil signs of oil.
  11. Newber
    Newber New Member
    I also called the dealership. Guy is telling me to run a tank of premium fuel with fuel injection cleaner and clean throttle body intake. Spoke to both dealers and nothing ever noted regarding the hybrid battery during service reports.
  12. jerrymildred
    11,517
    14,171
    Tampa, FL
    Well, there is definitely something wrong with it and I'll bet the sell knew it. That would be completely unacceptable to me. I'd take it back. You can do WAY better.
  13. Robbski
    Robbski Junior Member
    24
    31
    Massachusetts
    Premium gas is meant to prevent knocking in high compression engines. If the manufacturer does not stipulate its use (and Toyota does not for the Prius) it will not do a damn thing other than cost you $.50 a gallon more.
  14. Newber
    Newber New Member
    So I drove it again yesterday and turned the AC off. Went from 38 mpg to 42/43ish quickly.
    Still going to take it to the local shop around here for diagnostics.
  15. Newber
    Newber New Member
    I did wipe the exhaust pipe and there was quite a bit of black char. I’m beginning to think the motor is starting to burn oil and this is causing my performance issue.
  16. JC91006
    16,939
    8,647
    Have you ran a car fax to see actually mileage and history?
    I think you shouldn't worry about the car just yet, drive it for a month and monitor the oil level. Don't assume anything. If there are no lights on the dash, things appear to be normal. Don't waste your money chasing a problem that may not be there
  17. Newber
    Newber New Member
    Just had a diagnostic ran. All cells/modules are good!!! Auxially battery good! I checked all service reports and the car was properly mainted.
    Think my issues were related to a combination of conditions I didn’t factor.
    Car sat for months not being used. Sat at a stand still in traffic for 30 minutes with AC on and radio draining battery. Went on a long uphill climb directly after depleting battery. Kept ac/radio on uphill.
    #17 Newber, Jun 13, 2018
    bisco and SFO like this.
