So I got an 3013 Code, freeze frame looks fine?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mavi, Aug 26, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Anyone have any idea, why this would give an error? I put in 28 modules are pulled from a pack and they all seemed fine under load.
    Attached is the VCI freeze frame..
    Edit: I meant 3016, not 3013.. same question applies.
    #1 Mavi, Aug 26, 2018
  2. dolj
    dolj Senior Member
    8,651
    4,401
    Wellington, New Zealand
    The attachment shows P3016.
    What are you using for a load?
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    I was using a headlight.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Clear the codes, make sure the engine is off, monitor the HV battery live and turn on the AC full blast. That will put about an 8 - 12 amp load on the battery. You'll be able to see if a module is weak.
    rbdigital likes this.
