So I got bit yesterday - Red Triangle, CEL, Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CooCooCaChoo, Dec 27, 2015.
  1. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    4C, even if you did replace that one block you'd still have an eleven year old battery on a low mileage Pri, Imo, you tackled it the right way.
  2. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Oh geez. I know how you feel, went from a downtown loft to a house with a garage just so I can work on my 911. My neighbors at the loft were not too happy when I dropped the engine and left in the parking lot :-P
    Okay, that block is compromised and causing you to throw the code, most likely P3006, Uneven charging...
    The better test is to take a reading under load and charging, this will confirm no other blocks are compromised.
    Initially, I thought I had one bad cell but with the detailed TIS load and charge test, I found 3 more suspect cells ( with the generous assist from members here, thank you Gentlemen! ). Will be doing the swap this weekend.
    If you are ever in L.A. and feel comfortable driving the car you can use my garage and tools. I would get 3 or 4 cells, just in case. If you don't use them all, you can always sell it or keep them as spares as other will certainly wear low in the future. I would also get a new bus bar with sensor side. The back side can be cleaned.
    PM me if you want to take a little vacation down south. :). No worries, No "puts on the lotions..."
    #22 DRACO, Jan 6, 2016
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    542
    Cow-lee-fornia
    2023 Prius
    Yeah, I've read a lot about the Prius hybrid battery and how even reconditioning or even replacing the bad cells isn't a sure thing. I plan on keeping this car along time. She only has 126k miles on her and so far has been good to me, which is one of the reasons why I just went ahead and replaced it.
    She's got a new lease on life now!
    DRACO likes this.
