So I had this 'my fault' accident . . .
Discussion in 'Generation 1 Prius Discussion' started by bwilson4web, Oct 15, 2012.
  1. bwilson4web
    16,531
    Pulling out of a parking lot, I was watching the traffic from the light controlled intersection and failed to see the car coming the other way . . . vision blocked by the parked SUV. Still, I should have crept out, a few inches at a time . . .
    No injuries, the plastic cover of my bumper had a triangular tear taken out which we found in the passenger-side, door jam. No frame damage to his 1994 Honda Accura but the front door needs replacing the rear door needs some metal straightened. All in all, a minor accident but one that has me thinking.
    I support the law adding review view cameras to all cars to prevent backup accidents. But I have noticed how little visual information we have. So I'm thinking of getting a 4-camera, security system that has four windows in the screen and mounting it in my car:
    • two front cameras located in the corners of the fender, air inlet looking across the car to the opposite side
    • two rear cameras located high in the rear window again looking across the car and down to the opposite side
    My thinking is this will cover the blind spots, give me a 'peek' when approaching a blind intersection and provide parking and backing assist. So instead of 'feeling the curb,' I'll see them in the camera as well as pedestrians, bicycles, and cars coming 90 degrees to my line of motion.
    Thoughts?
  2. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    It might be info overload. I do not like using my back-up camera for the most part as I find that I have a wider field of view looking over my shoulder. The camera gives a bit of tunnel vision and also makes me feel a bit removed from what is happening. Having a small screen split into 4 images I think would be tough to manage.
    The solution that seems very cool is what Cadillac is doing with the vibrating seat - the early reviews are that it works very well and is very instinctive. Unforgettably it is a new system offered at least for now only by GM, but perhaps it will make its way into other cars.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sorry to hear about the accident.
    Seems to me having cameras/monitor would be more distracting than helping.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I agree with everyone else......one might get to dependent on the cameras as well
  5. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    My neighbor has a Lexus LX 570 with the cameras like in the video...it works very well
  6. bisco
    52,841
    i would like a front bumper camera. when i come to a T intersection and i'm making a left, and there is room for cars to pull up on my right, i can't see anything coming from the right. might need a periscope to see over the vans, trucks and suv's tho!
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Sorry to hear about your accident. I must agree with the others on the info overload.
  8. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    I might start with a netbook and USB webcams. You can use either matlab like image processing, or even something like catspy/ iSpy to highlight changing pixels in red. When you are stopped most of the scenery is static.
    I have a feeling the small video in a security monitor will make it even harder to see and pay attention then to something like a cyclist when you are checking for cars.
    Though if you can route the security monitor output video to something like a Rear View Mirror Monitor, that might work.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Bob, I think you've got a great idea. Go for it.
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Well Bob, you just had the accident that I dread the most. Parking a large SUV or truck next to the entrance/exit of a parking lot is just asking for trouble. Somehow you have to pull out to see if it's safe puts you in big danger. Sorry you had to go through it.
    As far as cameras, you have a choice of hundreds to choose from. I would look for a small narrow field of view, and put one in each side of the front of the car. You have to take pains to water proof it good. then you will need either a Quad split unit, however I would go with a switch to select one at a time. For pulling out of parking lot, activate the camera that shows the traffic you will be merging with, that's the most important camera for that moment in time.
    Actually, come to think about it, just that one camera in the front would do the trick.
  11. bwilson4web
    16,531
    I surveyed Ebay yesterday and there are some interesting options for reasonable prices, $300-400. One thought is an 8-channel unit with digital recording. The advantage is I can use the external housing cameras for the corners. Then I can use the four inside the cabin to document what the driver and passengers see. For accident reconstruction or even a traffic stop, this would be the way to go.
    I'd really like a stereo camera providing distance metrics to common points found in the overlapping field of view. The time between frames between common data points would provide velocity data. I had already thought about having a camera inside the cabin looking out the windshield, corners.
  12. bisco
    52,841
    you can put one in the footwell so we can see where your feet are after you claim u/a!:D
  13. KK6PD
    4,003
    946
    118
    Bob, this is a quest that I have been bitten by also. My main concern is the resolution that the cameras have. Most of the small sealed units I have found are about 480, which is normal for NTSC video, but they have real wide field of 110° to 130°+ views. That kinda negates reading a license plate number most of the time.The narrow (90°) are much better for that kind of thing, but hard to find! I like the idea of a central recorder.
    Have you checked out "DealExtreme" here is the URL...
    car video - Free Shipping - DX
    I have purchased items from these guys 6 or 7 times, each time it took about 2 weeks to arrive, FREE shipping, they may be in China, but they have some interesting items!
    For a split second I considered those waterproof backup cameras, but then, everything would be backwards......duh...:D
