So.. is there any real MPG improvement in weight saving?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cyclopathic, Apr 25, 2011.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  2. ZitterZap
    ZitterZap Member
    76
    28
    Houston, TX
  3. Mark57
    2,945
    2,734
    OK
    That's close to what I've noticed when fully loaded.
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Weight savings have the most impact when the car is braking. Calculating based on fixed speed will understate the importance of weight. How close it will be to your actual mileage depends on your routes.
  5. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Wouldn't it be acceleration and braking? Also, the time you have the throttle more than closed, you have to use more fuel to get/keep the car to the speed you want. Also, as quickly as you want.
    Assuming you are braking on the flat, wouldn't it take longer to stop, and therefore get more regen?
    Anyway, I agree, the lighter the vehicle the better. EcoModders don't even like to fill up till they are on fumes since they are trying to consume the most fuel / weight. Some may even only half fill the tank.
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Carrying about 400 lb of extra weight dropped my mpg about 5-8. Wasn't able to glide or use SHM effectively.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,118
    45
    North Yorkshire, UK
    5-8 mpg? Eeek, I'd better start that diet :eek:
  8. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    just pick up midgets
  9. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    LOL ... well this is from about 58 mpg to 53-50 mpg. When the fuel saving techniques are more extreme, the inability to use them drops fuel economy back down to normal levels.
    I tried, but midgets are afraid of the Prius. Something about being closer to the electromagnetic radiation.
  10. Corwyn
    2,171
    659
    23
    Maine
    The braking is where the irretrievable energy loss comes from. Accelerating just turn chemical energy into kinetic energy (at a slight efficiency loss). Braking throws it away as heat. Regenerative braking gets some portion of that back as chemical, of course. You could claim that accelerating commits you to eventually braking, I wouldn't argue.
    The greater your cars mass, the more force is required to accelerate it (or decelerate it). That force is what you are getting back when you regeneratively brake. If you have ample space to brake slowly, you only lose the increased momentum in the 7 to 0 mph range. If not, you are more quickly out of the 100% regen braking realm.
  11. cyclopathic
    3,292
    547
    2014 Prius c
    just for comparison:
    reducing rolling resistance by 30% (typical better "green" tire) will improve MPG by 12.7% at 60MPH, 18.3% at 45MPH.
    cost of new green tires ~450$
    green tire premium over regular tires ~100$ (25$ per tire).
    cost to make car 200lbs lighter ....
  12. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I notice the differnce when I have other people in the car.
  13. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Power to Weight ratio, the oldest measure of a performance machine. British battle ships put copper bottoms on their hulls to keep barnacles off a few hundred years ago. This made there ships fast while adding weight. This is one example of imporving performance without lowering weight. So if we wax our car & keep it clean we should see improved MPG?? Same prinicpal for getting lower rolling resitance tires/ over inflating them to at least 42f/40r to get better MPG while not loweriing the weight of car. Both ideas have helped other machines in past.
Loading...
