So my 2010 Prius III blew a hole in the engine last night...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by justinope, Nov 30, 2016.
  1. Simonak
    Simonak Member
    I say clogged EGR cooler and I hope you all did clean it before installing new engine.
  2. Mendel Leisk
    41,297
    @danlatu had a hydrolocked piston on the engine he rebuilt. Initial issue was just blown head gasket I believe. When he had the head off he noticed one piston maybe 1/8" low at Top Dead Centre. The rod on that piston was bent IIRC.
    Blown Head gasket rebuild....@297k | PriusChat
  3. 7om
    7om Junior Member
    United States
    So this same thing happened to me. It was more sudden, no smoking, no evidence of low oil, no drinking coolant… but alas after hard shaking on the highway, loss of power and a bunch of hazard lights I have the same hole in my engine.
    I want to do the engine swap you did. How do you guys recommend I go about finding an independent Toyota mechanic to do the swap? I saw a price in this thread for ~$350. That seems like a steal to me. Any advice on how to find a similar deal locally? I live in Costa Mesa, CA 92626.
    thanks in advance to anyone who can help
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Given you are in So Cal, I'd recommend contacting @RightOnTime and getting the swap done there;).
    He's done this activity a time or two:).
    Good luck (y).
    m.wynn likes this.
  5. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Haven't been on here in a while since I got the C-Max Energi and sold the '10 Prius. Next trade, I'll definitely go back to the Prius, so many things I like about it and so much easier maintenance. I'd like to know if the Gen 4 has the same oil consumption as the Gen 3 and also did they fix the EGR cooler issues. I won't be trading before late fall or early next spring so I have some looking around time left and it will be good to get back here.
    CR94 likes this.
  6. Mendel Leisk
    41,297
    No and yes.
    there is an issue with coolant leaking in the exhaust heat recovery system, but Toyo seems to be acknowledging and fixing it.
    jerrymildred likes this.
  7. milkman44
    591
    386
    Ky
    Good to hear, thanks for the reply..
  8. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Here is a prime example of this…..
    Had a customer come in with a blown Engine with this same issue
  9. douglasjre
    douglasjre Senior Member
    2,162
    714
    Null, NL
    If these engines failed because of high RPM or full throttle operation then all of my engines would have blown up a long time ago. My prius engines run at red line all day long and I do not have premature failures
  10. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    What mileage do these engines have? Why do you run @ redline?
    I'm curious because I like to do pulse and glide in the city.
    moto g power ?
