So now what?
Discussion in 'Generation 1 Prius Discussion' started by depriusoto, Jun 19, 2017.
  1. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    As far as I can tell Optima now longer makes the Yellow Top 12volt replacement battery for the GEN 1 according to the corporate web site.
    The supplier I've used for the last 12 years, Elearnaid, may have supply problems as they have been unable to fill my order after 2+ weeks.
    And as we all know to well, NAPA, O'Reilly's, Autozone, etc etc can't even find the Gen 1 in their data base.
    Searching through the posts here I found nobody's posted about sources for replacement 12 volts since 2015.
    So, now in 2017 where are folks finding replacement 12 volt batteries?
    Ed K
  2. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    Can't you just pick out another battery that physically fits into the battery hole? Does it even matter for the Prius what battery you get? It doesn't really even start the engine.
    If you want to go with another Optima to be sure, then I assume the only problem would be the layout of the terminals (+/- switched sides), right? I'm sure it would be rather trivial to make an "extension cord" using a cheap Chinese battery terminal, some 8 gauge wire, and a lead rod (or a copper/brass bolt). Ground should be easy since it's just a wire that's bolted to the bare metal in the trunk.
    #2 primuspaul, Jun 20, 2017
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    #3 Brian in Tucson, Jun 20, 2017
  4. Mendel Leisk
    42,343
    What does the dealership offer? Between that and other aftermarket offerings, there's gotta be some solutions.
  5. PriusRox
    PriusRox Junior Member
    29
    2003 Prius
    I
    Crazy as it may sound, in a pinch, I used a 12v garden tractor battery with no issues.
  6. Pri-Eye
    Pri-Eye Junior Member
    34
    Metro Detroit
    2001 Prius
    I use the 35 Ah AGM battery from Harbor Freight. (Thunderbolt Magnum Solar - item 68680)
    With a 20% off coupon it's still under $60 (assuming upto 7% tax).
    The top contacts are different and reversed, so you'll have to buy two new wires to connect the battery, and connect it to the positive contact block.
  7. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    Or you could find a similar type of battery with the terminals on the correct side and M6 threaded terminals. You can then get JIS (Pencil Post) to M6 converters. Tons of 12 V battery options with M6 threaded terminal, even put 55 mAh too.
  8. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I use a lot of HF tools, tomorrow I'm gonna use my 25% off coupon to get a clamp multimeter to check amperage draw in 120 v wiring. So I'm not one of those who complains about the tool quality at Harbor Freight.
    That said, my experience with batteries (mostly ni cad & lithium power tools) has been consistently bad. I don't think I'd chance a cheap battery in my Prius, at least not from HF. I figger it would leave me by the side of the road There are lots of different batteries available, I'd try a tractor battery before I'd try a solar battery, road use is a fairly rough life--every pothole, expansion joint, and speed bump transmits a physical punch to a battery.
    Coupons: Harbor Freight Tools Email
    I'll delete after the coupons expire.
