So what is your carbon footprint?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cyclopathic, May 10, 2015.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It takes about 100 kWh of fossil fuel (coal, gas, nuclear, renewable - grid mix) to produce 33.7 kWh of electricity.
    Once it is produced, EV is very efficient to run. The problem is the fuel production.
  2. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Mine was so far off I wonder what they're doing? The vast majority (95%+) comes from renewables. Hydro, wood, wind. Yet that site shows almost 30% nuclear, which we have none of.
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    HEV in the graph is not Prius but a 42 MPG hybrid. PHEV is the Volt.
    50 MPG Prius emits 222 g/mi while PiP would emit 230 g/mi.
    Beyond Tailpipe Emissions: Results
    Volt would emit 280 g/mi.
    You are better of with a regular Prius or install solar panel so you can cut daytime carbon footprint.
    giora and cyclopathic like this.
  4. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That's correct for coal, since that has ~3kWh/lb of energy and we use ~1lb of coal to generate ~1kWh of electricity...
    SAS Output
    SAS Output
    This would correspond to ~2+lb of carbon per kWh of electricity given the carbon emissions of coal at 33% efficiency.
    How much carbon dioxide is produced per kilowatthour when generating electricity with fossil fuels? - FAQ - U.S. Energy Information Administration (EIA)
    However, US electricity emissions are ~1.1lb/kWh, which means that at the current grid mix, it takes ~68kwh of FF to make ~34kWh of electricity.
    Electric Power Annual 2013 - Energy Information Administration
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    According to EIA, 2/3 of energy is lost at the power plant and power lines. They are referring to the grid mix of everything.
    That means 67 kWh is loss and 33.7 kWh makes it to the outlets. Total fossil fuel started should be around 100 kWh.
    On the other hand, it takes 50 kWh of fossil fuel to generate 33.7 kWh (gallon equivalent) of hydrogen.
  6. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That's accurate for coal power (and probably single cycle natural gas) plants in terms of carbon emissions, but it doesn't apply to the grid as a whole, since nuclear isn't as carbon intensive although the thermal efficiency is probably in the ~33%-50% range, and hydro/wind/solar/geothermal/etc... (mostly) don't use thermal power plants and also aren't as carbon intensive.
    All of the information I linked in my last post is from the EIA as well. Total carbon emissions versus total generation is about half of what it would be if we had nothing but FF plants running at ~33% efficiency. That's partly because of nuclear/renewables, and partly because of incremental improvements in FF generation efficiency.
  7. fuzzy1
    10,437
    It may be doing the same to you that it does to me: aggregates many states (and portions of other states) together, and gives a single answer for the entire block. It doesn't really drill down to a specific zip code, or even a single state.
    Try some sample zip codes at varying distances from your home, and see how far away it produces the exact same result. And be sure to run your samples in several different directions.
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It is probably driven by the data from eGRID. Here is the map.
  9. fuzzy1
    10,437
    I'm in the yellow western block of that map. My zip code is aggregated to include roughly between one-third and one-half the land area of that block, but I detected at least three other zones within that yellow block.
  10. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    fuzzy1 likes this.
  11. fuzzy1
    10,437
    It clearly lumps in far more than electricity. The per-zip-code results seem to correlate to typical household wealth, at least in my local area.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Very true...
    And reminds me chart I have made and submitted long ago in another thread:
    (Volt 85% means 85% EV and so on. GHG emissions include "up-stream" emissions)
    #72 giora, May 26, 2015
