So why 175/65R15??
Discussion in 'Prius c Main Forum' started by cyclopathic, Feb 23, 2012.
  1. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    Corrected in my list. It's still noteworthy that they list that tire at lower RPM than any other 175/65/15 unless 856 is just a dyslexic typo for 865.
    865 175/65/15 Yokohama AVID ENVigor
    856 175/65/15 LRR Continental ContiProContact### (mislisted on tirerack.com as 844)
  2. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    Does the suspension upgrade on the 16" mean it should have a smoother ride? Also, in Canada we have only three trims: Standard, Technology, and Premium Packages. The premium package comes with 16" alloy wheels for about the same price as your c 4 with tire upgrade.
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    All else being equal, the 16 inch wheels would give a little rougher ride but it might not be enough for you to notice the difference.
  4. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    From the Edmonds review they say the 16" wheels have a much larger turning radius than the 15" wheels. What other advantages / disadvantages are there between the two?
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Yes the radius is much larger 37' vs 31'.
    15": higher MPG. Turning radius (by 6'!) Marginally better acceleration
    16": Bling factor . Slightly better side grip/handling. Marginally better braking.
  6. formula
    formula Member
    320
    32
    CA
    they make 14inch for Prius C in Japan. I would like to have 14 inch. :)
  7. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    I notice on the Toyota site that the 15" alloys are only available for the model III and IV (standard on the IV and optional on the III). Does anybody know if there's some physical reason why these alloy wheels wouldn't fit on the I and II models?
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    They should fit on all levels, if not someone
    should not have been an engineer.
  9. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it is simply how they sell them, only attached to those models..
  10. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    With tires, the smaller the width, the more is the MPG. A regular 175 tire should give more MPG than a low-rolling-resistance 185 tire.
    tires-easy.com has 25 different selections for this tire size:
    175/65R15 tires on tires-easy.com
  11. cyclopathic
    3,292
    547
    2014 Prius c
    Not sure if this is the case. Most of rolling resistance comes from sidewall. IIRC Nokian boasted that their hakkapeliitta r winter tire to be the lowest rolling resistance tire they made, all due to sidewall construction improvements.
    EU will be requiring all tires sold to have rolling resistance on posted side wall, same way as threadwear/temperature/etc is. Then we can compare oranges to oranges good luck
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    No, but if you do replace them you need to get the steering adjusted.
    The reason the 16" turning radius is larger is that they limit the steering so that the tires don't rub on the car. :D
  13. CptQuantum
    CptQuantum New Member
    Takoma Park, MD
    It really is quite simple. If you drive straight ahead, the inner and outer edge of the tire tread travel the same distance. If you are turning (or navigating a winding road), the inner and outer tire tread are travelling different distances. This means you are always scrubbing the tire tread when you are not driving straight ahead. The wider the tire, the greater this effect! Not only does this increase tread wear, it reduces your MPG! If you bought your C to enjoy fuel efficiency, don't put wider tires on it!
    ______
    Prius c III, moon-roof, absolutely red
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    There is also evidence in theory that a wider tire will lower RR up to a point but it gets really screwy because CdA changes as well. I gave up trying to second guess the manufacture and I will just stick with 195/65/15s. lol
  15. R11
    R11 New Member
    101
    17
    Portland, OR
    Not sure where you got this but it's incorrect. Only the IV's with the 16" alloys have the turning-circle-limited steering set up. Nothing would need changing for the 15" alloys on the I, II or III models.
    ron
  16. cyclopathic
    3,292
    547
    2014 Prius c
    Not sure it is such a big factor. The difference btw 195 and 175 on a full 360 turn will be less then 5" (4.95" to be precise), half of it on 185 series.
    Most of the time car is going in a straight line anyways. My 15mi commute has an equivalent of 2.5 360 turns, most of it in 1mi getting out of neighborhood.
  17. CptQuantum
    Takoma Park, MD
    If you need more proof, go out to a parking lot (where it's very quite), roll down your window and listen to the difference in noise level when you are going straight versus turning. Assuming your wheel alignment is okay (which will also affect MPG), the difference in noise is due to tread scrubbing. I won't argue as to whether the effect is small or large. You are listening to increased friction.
    Try it...
  18. cyclopathic
    3,292
    547
    2014 Prius c
    ^^ I have no doubt there is more loss due to friction. Question is how much impact it has?
  19. Randyneely
    Randyneely Junior Member
    23
    chico
    Whats the mpg on a prius w/ 17 " factory wheels....same as 15'' ??? just wondering.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    it is worse.. a few MPG less. One of the reasons I am not getting larger wheels.
