SoC drains to two bars every other night
Discussion in 'Gen 2 Prius Technical Discussion' started by goitalone, Aug 11, 2011.
  1. uart
    uart Senior Member
    4,220
    1,212
    Australia
    You and the OP could both take 2009Prius's advice.
    When the car is first started, depending upon the circumstances, there can be a high initial demand on the HV battery and the charge can drop relatively rapidly.
    Some things that can exacerbate this are
    - A lot of A/C required. When the car is heat soaked the A/C has to work very hard to initially cool the car. All it's power is drawn from the HV battery. If you can have the AC off and use the windows down to get the heat out for the first few minutes of driving before switching to AC (and putting the windows up) then that can really help.
    - Poor condition 12V battery. This will lose charge rapidly, especially in the heat. When you start up with a low 12V battery the DC-DC converter works hard to recharge it rapidly and draws it's current from the HV battery.
    - Even when the temperature is warm the cat's will still be too cool for the engine management system to fully use the engine power for the first 30 to 40 seconds. So the car will preferentially run on electric power for a short while.
    So you see everything can be hitting the HV battery hard for the first few minutes after start up. If you let the engine idle in park for 30 to 40 seconds before driving it makes quite a big difference to how well the HV battery copes here.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Check the easy stuffs (12V lead acid battery, etc..) as others suggested. If you believe the issue lies in the HV battery, you can do the following.
    You can get a $49.95 OBDLink SX OBDII USB adapter and use PriiDash software to pull data of your HV battery modules. There are 14 modules and by looking at the voltage and internal resistance, we can compare the health of each modules. I am sure 2009Prius can help you out with the graphs. He has done it to compare mine (2006 with 150k miles) and his (2009 with 20k miles). I'll be interesting to see how they compare to yours.
    Alternatively, you can get $85.81 Kiwi bluetooth OBDII adapter from Amazon plus $5 Torque app from Android marketplace and pull the same data. You can even view LIVE data from an Android phone.
    You can mark down the State Of Charge (SOC) of the battery pack right before you shutdown and compare the SOC upon the next day start up. If the difference is too great, the HV battery is draining overnight.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    OK,
    Forgive me if this question seems insulting, but sometimes it helps to address the most basic questions, so that we are sure are assumptions are correct.
    When you exit your car after driving, you do "power off" the car, correct? If you left the car in a "ready" state, it would slowly drain the traction battery over time and the engine would run to charge it. I'm guessing you do shut it down, but on the off chance you aren't, this would be a simple way to address your problem.
  4. goitalone
    goitalone Member
    190
    16
    Port St. John, Florida
    *deleted post
  5. goitalone
    goitalone Member
    190
    16
    Yeah, mine drains from full charge to nothing overnight and the enigine runs really hard and loud for the first 5 minutes or so, but its still loud even after the SoC is showing it has charged back up....just not as loud as the first 5 minutes.
    Almost seems like a slipping transmission while accelerating.
    My mothers 2006 is very very quiet and has a lot more power than mine at any given time.
    I also hear a slight pinging in my engine...maybe it is going bad too!
    I am going to take it to Toyota later this week. Hope they don't try and take me for everything I HAVEN'T got just to test it!
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It sounds like he shuts it down because when he started up, he sees (6?) blue bars and suddenly it became (2) pink bars. That's how I interpreted it.
  7. goitalone
    goitalone Member
    190
    16
    Mine SEEMS to charge quickly too, but who knows, maybe its not even accurate on the display.
    I was told by Toyota that if anything were wrong, I would be seeing some kinda warning messages on the dash.
  8. goitalone
    goitalone Member
    190
    16
    Where do I plug the OBDII USB adapter in at?
  9. goitalone
    goitalone Member
    190
    16
    Yes, I always power the car off completely and nothing is left on in or out of the car.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    The engine has to work harder if the battery is not assisting or unable to. If there is a weak cell in a module, it can do that. My guess is, the car may not throw an error code if the threshold is not reached yet.
    The only way to tell is to use a OBDII scan tool. Dealer has that tool but they may not tell you the results but you can ask for it.
  11. goitalone
    goitalone Member
    190
    16
    Correct! Sorry if I did not explain it very well.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You plug OBDII side to the OBDII port under the steering wheel and the USB side to the computer.
  13. goitalone
    goitalone Member
    190
    16
    Thanks, I will ask for the results then if I go...er when I go I guess.
    I am afraid to find out how bad it is though...just spent 10K on this thing :(
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ok! So with a OBDII tool, you can capture the battery State Of Charge before you turn off the car and compare it when you turn it on the next day. You'll be armed with the percentage of loss over the number of hours.
    Not all the OBDII readers can show the hybrid battery SOC. The ones I suggested are the cheapest if you already have a laptop or an Android phone. If you have neither, get a ScanGauge II which comes with a screen.
  15. goitalone
    goitalone Member
    190
    16
    I think I will go ahead and get one and see what it shows. I will post results here later on.
  16. goitalone
    goitalone Member
    190
    16
    I have laptops, so I'll do OBDII I guess. Thanks for the info.
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Florida is a CARB emission state so the hybrid battery has 10 years / 150k miles warranty. The catch is, that started in 2006, so prior year models may only have 8 years / 100k miles coverage. Check your owner's manual and it should be in there. If you are covered under warranty, we'll worry about getting Toyota replace it for free. They wouldn't want to replace it without an error.
    In order to do that, you'll need to have hard numbers to present and OBDII tools can provide that.
    I think getting OBDLink SX is the cheapest option but it is a bit tricky to set it up. Torque app and Kiwi is easier but you need an Android phone. If you don't have one, you can get a used one for $50-$70. SGII is easiest to setup but it can only pull the HV battery SOC. It cannot pull individual module voltage and resistance.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    See this thread to get you through with the setup. Once it is up and running, it'll automatically log the HV battery information in your F: drive.
  19. goitalone
    goitalone Member
    190
    16
    Cool, thanks again!
  20. goitalone
    goitalone Member
    190
    16
    The guy I bought the car from said there was a recall and that he had it replaced, but I will take a look and see anyway to make sure.
    One thing I forgot to mention as welll, is that my A/C is not nearly as cold as my mothers Prius. Not sure why, but thought it might have something to do with whatever else is wrong with the car.
