Soc falls and rises
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Yuriy, Dec 11, 2023.
Tags:
  1. Yuriy
    Yuriy Junior Member
    23
    Russia
    Hello everyone After installing a new battery from li-NMC cells, incomprehensible problems with the battery began, namely: During normal operation of the machine, the battery soc can sometimes drop to 1%, work a little and then rise to almost 85-90% Soc. it does not depend on the battery voltage. please help me what to do in this situation, what to watch and check, it seems to me that the battery control unit is the problem, but the algorithm of its operation is not clear
    52,849
    not sure if those cells work with the bms properly, but aside from that, it could be the installation or other parts inside the battery case.
    any trouble codes with tech stream?
  3. jacktheripper
    jacktheripper Senior Member
    284
    558
    !!! NMC lithium chemistry is too dangerous to put on a Prius !!!
    @Yuriy the up and down means the pack has been overcharged, please get it off your Prius for your safety!!!
    Brian1954 and bisco like this.
  4. Yuriy
    Yuriy Junior Member
    23
    Russia
    there are no mistakes, I have been driving normally since August, everything was fine, but now the frosts began and along with this problems, the mileage on a full charge of 5 km
  5. Yuriy
    Yuriy Junior Member
    23
    Russia
    Why are they dangerous? do you mean ignition of lithium during overcharging or damage to the cell?
  6. Yuriy
    Yuriy Junior Member
    23
    Russia
    I was driving to work today and the same situation happened, that the voltage is rising and the charge is decreasing
  7. Yuriy
    Yuriy Junior Member
    23
    Russia
    li nmc perform very well in operation, do not heat up, they have a small internal resistance, about 0.6 mohm
  8. Yuriy
    Yuriy Junior Member
    23
    Russia
  9. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    faster than "normal" changes in SOC is usually one or more bad battery(s) within your pack. Since they're arranged in a serial fashion, you only see a weak block - depending on how accurate your diagnostic software is. You'll need to remove the bus bar and test each individual battery to find the weak/faulty unit(s). Your OEM diagnostic software isn't going to be much help, since it was programmed assuming nickle metal hydride batteries; the discharge/recharge curves are vastly different.
    Hope this helps.....
    Yuriy likes this.
  10. Yuriy
    Yuriy Junior Member
    23
    Russia
    thanks for the answer, the cells are all balanced and their voltage differs by no more than 0.3-0.4 volts if you look at the original batteries (1-14 cells)
  11. BiomedO1
    4,594
    2,410
    Left Coast
    Did you load test each individual battery? Voltages doesn't push the car amperage/watts does.
  12. Yuriy
    Yuriy Junior Member
    23
    Russia
    I checked each element for capacity, all about 6.9- 6.8 ah
  13. Yuriy
    Yuriy Junior Member
    23
    Russia
    maybe someone has information on flashing the high-voltage battery control unit?
  14. Leonid Igaev
    Leonid Igaev New Member
    Novosibirsk
    Yuriy,we have some work of upgrade hv batteries of Honda Civic 2005-2009 and Toyota Prius Nhw 20-30 last 3 years.Earlier we applied Gsyuasa cells from Honda hybrids,now China li-ion cells 6ah.At Honda we have not problems with a battery behaviour in winter.It works normally.But with Prius we got a stable phenomena with Soc missing and graths jumping at monitor and Ice revving dangerously and so on.Such picture we monitoring not winter only but at summer weather sometimes.We supposed a capacity weakening with a cold condition,so a complicated Toyota Soc estimation algorithm is destroyed and cannot to find a real Soc meaning.Such reasons may be a low capacity with age and temperature factors .Some owners wrote here a similar examples with Nimeh Oem Prius batt.But in Siberian weather all Honda hybrids works normally.We think to add some local heater at hv battery for task desigion.Excuse my English,no practice.Thanks.
