Socket size for sparks plug?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Luna3, Jul 4, 2016.
Tags:
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No way! I though he was referring to me!
  2. Superleaf444
    Superleaf444 Junior Member
    25
    I just found this thread, while looking to make sure which tools to pick up. New wrinkle. Denso looks to have updated the website from 14.2mm to now say: 9/16" (14mm). The world is chaos.
  3. Mendel Leisk
    42,264
    14 mm is slightly snugger. I've used 9/16"; thought that was the official size, but considering it's Japan probably 14 is the way to go if you can find it in a spark plug socket (rubber insert to grip the plug).
    Superleaf444 likes this.
  4. Beeach
    Beeach Junior Member
    22
    virginia
    I was excited receiving the 3/8 drive GearWrench 5 pc magnetic spark plug socket set with 9/16 & 5/8 sockets that NutzAboutBolts recommends. And it seems that 9/16 and 14mm are considered swappable but I am going to get a dedicated 14mm instead. I won't be removing the spark plugs all the time and risk rounding the corners but 14mm is the proper recommendation for a spark plug job.
    FreeFly and Mendel Leisk like this.
