Software update from Feb 2020?
Discussion in 'Prime Main Forum (2017-2022)' started by mistermojorizin, May 4, 2020.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    This is supposed to fix the issue with random reboots.. mine does suffer from that so thanks!
    illumiN8i likes this.
  2. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    No dealer needed. Follow the instructions in the link on the first page and in the PDF file I linked to.
  3. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    I suspect the website is incorrect but the TSB PDF I linked to is right in saying that it also applies to the 2017. Just check your current software version and compare it to the table in the TSB to make sure the update is for you.
  4. schja01
    schja01 Senior Member
    1,848
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    So where are the actual instructions to perform the update?
    2018 Prius Prim Advanced JBL Nav
    I can download the KWI file but where the instructions are suppose to be I get this:
  5. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    I linked to the instructions in a previous post in this thread. Uploaded here for reference.
    TGrracie and MrBugMan like this.
  6. schja01
    1,848
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks. I missed your original link.
  7. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    For those who have a 2017 Prime and aren't sure if this update applies officially, note that the release notes clearly includes the 2017 as a covered year.
  8. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    mine recently "fixed itself" from the reboots - it spazzed out (kept rebooting) until it somehow factory reset itself back to the state it was when i first got the car (had to repair my bluetooth etc). no more reboots.
    so if the update doesn't fix it, look into how to do a factory reset. or maybe try it before the update. maybe, just sharing my experience
  9. Heedunk
    Heedunk Junior Member
    61
    23
    Bay Area
    2020 Prius Prime
    I have a 2020 Limited and the update says not compatible when I insert the USB drive. I clearly have an older software version (R20A2200). anyone have the same problem?
  10. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Same. Reported it to Toyota and got a case #. It was a wild goose chase.
  11. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Same for me. I downloaded it twice, and tried various formatting standards (fat32, ntfs). Same issue. Hope they release a fix for it.
  12. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    has anyone tried this with the 2020 Limited?
  13. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Yes, read the other posts about this above. It doesn't work on the 2020 even though the documentation says it does.
  14. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    i did read the earlier posts, that's why I asked. Wondering if anyone has tried it since those posts. I don't know if Toyota has fixed it yet.
  15. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Ah, I didn't realize you had read the posts. I checked the download file again today and it hasn't changed. Perhaps someone with a techinfo subscription could check if the correct update file is available through that service.
  16. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    New info: I found an updated Technical Service Bulletin that references the proper update file 16TABDNA-AA02_3000.kwi for the 2020 Prime. https://static.nhtsa.gov/odi/tsbs/2020/MC-10174878-9999.pdf
    Unfortunately it doesn't include the the update file itself and the download site is still linking to the wrong one.
    followingalex, garglo and GSK like this.
  17. Elektroingenieur
    2,515
    3,287
    Three Touring
    If you get a Professional Diagnostic subscription to techinfo.toyota.com (from $65) and access the same service bulletin there, the download links on page 4 should work. They’re relative links that work only when the PDF document has been served from a Toyota website.
    The “securedp.toyota.com” site, on the other hand, remains a mystery; this wouldn’t be the first time it’s had incorrect information or out-of-date software.
  18. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Well, kind of older thread but I updated my 2017 Advanced to the new software. As others have said, it takes a heck of a lot longer than 10 minutes. Just make sure if you try it, have the "engine" running. Don't just do it on Acc... (it automatically shuts off after 20 minutes), don't ask me how i know!
    Salamander_King and illumiN8i like this.
  19. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Did it just shut off... or did you have to jump start??? lol
  20. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    No update for the 2018 small screen.
