Software update problem
Discussion in 'Gen 2 Prius Main Forum' started by oneartist, Dec 22, 2018.
  1. oneartist
    oneartist Junior Member
    I'm using an Amazon purchased Mini-VCIj2534 cable for my 2006 Prius. When I connect to my computer, I was asked to update my Techstream software. Since I'm not a dealer, I picked the bottom selection? The site has an old user name I used long ago at Toyota but I cannot get past the password. I've changed my password. Nothing works. I called the help number on the right side and they asked me for my dealer number. I said I was not a dealer. I was given another number for non dealers but no response.
    After I reconditioned my main battery using a Prolong Charger/Discharger I got the red Triangle. Maybe I should go back and make sure my main disconnect is correctly hooked up.
  2. Patrick Wong
    18,200
    6,479
    Mini VCI is bootleg software, therefore if you expect it to work you need to follow the installation instructions and disconnect the laptop from Internet access.
    Skibob likes this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    It’s bricked. Uninstall the software and reinstall it but read the directions on how to install it before you try again, I think you missed a step. Also don’t have your computer connected to the internet when you use the program. It tries to phone home and bricks itself.
