Softwware Glitch in the PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by LenP, Mar 27, 2012.
  1. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I dont think that's true. I think the ICE running is still dependent on heat whether the AC is on or off. I've definitely used AC (cooling) while in EV. The remote AC works just on battery power as well.
  2. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Thank you for the confirmation of my assumption, that running the AC should not require to run the ICE.
  3. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    This makes me wonder if a kerosene heating system of some sort might be utilized in future EVs.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    A possible new habit pattern for Pip owners can be to power ON (instead of READY) and adjust the climate control below OAT or LO, before starting out.. then power to READY.
    Its better for me to set it before starting out, instead of before shutting down.
    How do you get power ON you ask, 2 pushes of the Power button without a foot on the brake pedal ---adjust climate control----
    from that point READY mode will be one more push of the Power button
    with a foot on the brake pedal
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Unless the temperature setting is on LO, you're telling the system to run the heater. It makes no difference what the outside temperature is. LO means "give me outside venting only". All else is will cause the engine to start.
    In other words, there's no glitch.
    True, there could be a more eloquent of specifying & indicating that. But those of us having driven a Prius for many years already knew what they meant... hence me not having the engine start.
    Lastly, it looks like the video link in my previous post didn't appear. Here it is again... http://priuschat.com/forums/toyota-prius-plug-in/105347-phv-prius-owner-videos-2.html#post1507987
    4 people like this.
  7. essaunders
    essaunders Member
    195
    NH
    Just be glad the Prius HVAC design gives you the "LO" option. In the LEAF we dont' have that option If it is "chilly" outside but I want venting only I get to open windows.
  8. LenP
    LenP Member
    257
    69
    Morris County, NJ
    For the most part AC being electric seems to run without the ICE almost all of the time. I had the ICE come on once. why who knows.
  9. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    I had this happen to me twice in a week I had a demo PiP. Both times, I was standing still with the car.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    So you turn the temperature down past the point where it would want to engage the A/C, but at the lower limit there is a special value "LO" that will engage neither the A/C nor heat? Or do you have to explicitly turn off the A/C so it doesn't try to give you an Arctic experience in your car?
  11. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Heat is what requires the ICE to be running. A/C runs on electricity and is independent of heat, i.e. the heater can be run w/ A/C (for dehumidification) or w/o A/C. The advice to set it to LO is to make sure the heater is off.
    I've had heat start the ICE a couple times unwanted. I want to see if I can get away with climate control off and heat warmers in those cases, but I'll need to get in the habit of turning the climate control off (b/c I don't know what the threshold for turning on heat is based on ambient temperature) when it's cold. Maybe I should just always turn it off when I shut off the car and require a deliberate choice to turn it on.
  12. bisco
    52,804
    that's what i have always done. except when i forget.:p
