Solar eclipse 2017
Discussion in 'Environmental Discussion' started by tochatihu, Aug 21, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    We are headed for St Louis area by minivan due to traveling heavy with telescopes and my mom, who always brings a lot of stuff - coolers etc. Mom is getting dropped off to visit family so after that we will go wherever we have to go based on weather traffic.
  2. tochatihu
    tochatihu Senior Member
    9,989
    3,858
    Kunming Yunnan China
    2001 Prius
    A few days of unusually congested roads. NW states are in and may remain in a hot bubble. 2017 wildfire season is above average so far but not setting records.
    If you are short of things to worry about, there will be many people with minimal fire-safety skills, plus fuels, plus road bottlenecks, plus heat.
    Might end up wishing for clouds and rain after all :eek:
    RCO likes this.
  3. fuzzy1
    10,714
    If the wildfire smoke keeps up, viewing might even become safe without optical filters. Only respiratory filters will be needed. :-(
    Compared to a week ago, the smoke has reduced my PV production by 25% for the whole day, 32% at peak. And it isn't because of high temperatures (PV efficiency drops at high temps), because the past two days have been cooler. At least the surface air quality here as improved, as an on-shore flow of marine air has displaced the lowest level smoke. But if that flow subsides, the smoke at higher levels could quickly mix back down to the surface.
    (The Today image is for Aug 6.)
    Cliff Mass's Weather-Climate blog mentions a 70% solar attenuation at Twisp earlier this week. I can personally attest to it being very bad there Friday morning, contributing to some bicyclists not being able to pedal up over the mountain pass that morning.
    Cliff Mass Weather and Climate Blog: Smoke Starts to Recede as Marine Air Pushes into Western Washington
    Please, people, don't do anything that starts any more fires.
    #23 fuzzy1, Aug 6, 2017
    RCO and bwilson4web like this.
  4. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Does anyone have a good site that forecasts cloud cover.
  5. DavidA
    2,349
    1,825
    Chicago western burbs
  6. fuzzy1
    10,714
  7. DavidA
    2,349
    1,825
    Got a couple eclipse glasses for less than $2 each from American Science and Surplus. They work. Thing is, if you wear prescription glasses, you need to combine them to see the Sun clearly.
    My 77mm camera lens filter came from Thousand Oaks Optical. Works very well and is quite a bit less $ than other competitors. That took 6 or 7 weeks to arrive, and I ordered it at the beginning of February. No hope of them delivering one in time now if you order from them.
    Both of those vendors are on the list that was linked above.
    Definitely you need to trust your vendor. Too many unsafe fakes out there right now.
  8. bisco
    52,863
    can i glance at it for a millisecond?
  9. tochatihu
    9,989
    3,858
    2001 Prius
    (Gonna regret this but...) yes you can gaze upon El Sol directly, briefly, and without lasting harm. I bet many here already have done so. The point is, there is no point in doing so.
    You overload optical organ, scattering light every which way, and obtain no data, can't form an image. That is 'fast response', your eyes will turn away or blink. Can only be over-ridden by 'biochemicals' that PriusChat does not endorse :)
    I suppose a sober person cannot force their 'gaze upon' long enough for actual pathological retinal heating. Please do not attempt to prove me wrong!
    Things get dodgy during eclipses if there are substandard eye filters available. As sun is getting more shadowed, people want to see it. This is danger time where bad equipment lets you fix gaze on sun and actually admit enough milliwatts for retinal cookery. Don't do it. This is what all eclipse sites shout about.
    I will make a different plea. What you really want to see is solar corona up there, and dynamic darkness down here. You can see those best if your eyes are darkness adapted prior. Time constant exceeds 3 minutes.
    I argue that folks who have black bags over their heads until second contact will have the best view of main events, having flipped their rhodopsin for high sensitivity. Few will be that strong! But third contact and after, let 'er rip and watch solar crescent growth. If your goggles are too 'bright', fold em over double and close the other eye.
    Main point is that two outer eclipse phases are symmetrical. Second is no less informative than first. Forgo the first and save your rhodopsin for the dimmer main events.
    Knowing people, I doubt that any will wear black head-bags early. But such could enhance perception of wind, thermal and sound.
    bisco and RCO like this.
  10. fuzzy1
    10,714
    I haven't read up on any modern changes to the old advice. But the old version was that the moment of third contact, the emerging 'diamond ring', was the moment of danger. With the eyes focused and in the process of getting dark adapted, and pupils opening up to admit as much light as possible, the sudden re-appearance of the sun's surface with no eye warning could cause a retinal burn. Binoculars or direct viewing through a telescope make it even worse.
    The rest of the time, the eyes could protect themselves. But I'm still running on mid-late 20th Century advice, without any 21st Century updates, so don't blame me if you get hurt.
    Your eyelids can't keep the glance that short. Nor can you focus that quick, even when young.
    #30 fuzzy1, Aug 8, 2017
    RCO likes this.
  11. fuzzy1
    10,714
    The good news: total smoke in the air column was down today. My PV system saw just 16% attenuation at peak production, 12% for the overall day.
    The bad news: the low altitude inflow of clean marine air fell, and vertical mixing increased, bringing more of that smoke down to the surface to irritate eyes and lungs.
    RCO likes this.
  12. fuzzy1
    10,714
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The prevailing Westerly Winds ensure that Cornwall is blessed with really fresh air, as there's nothing but ocean between our landmass and the Americas. Unfortunately we play host to many atmospheric depressions which deposit great volumes of rain in horizontal airstreams even during our summer. Today is overcast with rain! Still, that's better than wildfire and drought conditions I guess.
    #33 RCO, Aug 8, 2017
  14. tochatihu
    9,989
    3,858
    2001 Prius
    DavidA likes this.
  15. wxman
    wxman Active Member
    636
    231
    Tennessee
    According to the GFS ensembles ("spaghetti plots"), upper air configuration appears to be trending toward upper ridging over the central CONUS:
    Animation using Javascript Animation Player (frame #14 today August 9; will change every 24 hours; 00Z Tuesday August 22 = Monday August 21 @ 8 PM EDT.)
    Upper ridging typically results in cloud suppression. Convection this time of year typically occurs around the periphery of the upper ridging.
    Still too soon to tell with any degree of confidence, however, as spread between ensemble members is still too great.
    tochatihu and RCO like this.
  16. tochatihu
    9,989
    3,858
    2001 Prius
    Fascinating to watch the spaghetti diverge.
  17. tochatihu
    9,989
    3,858
    2001 Prius
  18. tochatihu
    9,989
    3,858
    2001 Prius
  19. bwilson4web
    16,544
    Spring City, TN looks to be a pretty good viewing spot. Now to see if there is someway to make a star-map photo and visit again in 182 days to make a second photo. Then compare the two to see if we can identify the gravity effect of Sol.
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Give me an outlook update ..we are committed ...in StL
