Solar Edge 3800 Wave inverter with built in charger
Discussion in 'Prime Main Forum (2017-Current)' started by Dave7, Jun 27, 2020.
  1. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    so far, with 4kw solar and the Prime, data is actual, the charge is not subtracted from the PV production upload_2020-6-27_7-36-45.png
    davecook89t likes this.
  2. Salamander_King
    Salamander_King Senior Member
    10,767
    8,696
    New England
    Is it grid-tied?
  3. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    yep grid tied, in my state the net metering is even, so I charge whenever. It does have a use solar first option so when the sun is shining it takes the solar electricity first. If the Prime needed more than 16 amps it would combine the solar and the grid for up to 40 amps.
    Salamander_King likes this.
  4. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
  5. PT Guy
    PT Guy Senior Member
    1,017
    681
    Washington, the state
    I'm not sure what you're showing us. The PV panels will produce all they can produce. If your house load (total house load including charging the car) is less than the PV panel production, some will be sold to the grid...and vice versa. Are you telling us that you're getting something, the car charge, for nothing? In the case of excess production the amount used by the car will be juice that isn't sold to the grid.
  6. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    Your correct, the EV charge is just a load, sometimes comes from the solar, sometimes the grid. The cool thing here is the solar inverter has a built in EV charger. It has the feature of pulling from the solar and grid at the same time. But that is not really helpful with the Prime 3.6kw draw.
Loading...
