Solar flip
Discussion in 'Environmental Discussion' started by tochatihu, Aug 6, 2013.
  1. tochatihu
    tochatihu Senior Member
    9,906
    3,836
    Kunming Yunnan China
    2001 Prius
    It's that time again
    The sun's magnetic field is about to flip
    I wonder if any of the non-mainstream solar scientists have predicted this? One would certainly hope so.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I'm sure there are going to be sharks involved!
    It is Shark Week after all, timing? H'mmm
  3. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Not really a big deal, as it happens every 11 years.
    But this one signals the downturn of a very weak solar maximum .
    The Sun will be degrading to a very weak minimal phase for the next 30 years.
    ie, very few if any ,sunspots.
    It will be an interesting experiment to witness the effect.
    The last 2 Solar minimums of this extent ,coincided with cooling periods
    causing crop losses and plagues .Witches were blamed for the poor climate.
    (Funny that the contemporary AGW BELIEVERS think CO2 is a witch and should be eliminated.)
    Im actually thrilled that potentially we will soon see evidence of whether CO2 or the Sun controls climate.
    This year there is already much evidence from weather of a cooling effect.
    If climate cools in the next few years you guys will all know you are full of BS with your CO2 theory ,and I expect an explicit acknowledgement of that if you are wrong.
    I know from experience in the political forum , that you guys chirp crickets when you are wrong.
    ( lifelong Democrat here but I knew Obama was BS.
    For example he Assassinated 3 American citizens without trial.Him being a Constitutional scholar.)
    I will respond accordingly with a full apology if the climate continues to heat.
    massparanoia likes this.
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    ^i wait with restless anticipation!
    I am going to book mark this page!
    Icarus
  5. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Yep...predictions as predicted....and sharks, too.
  6. austingreen
    austingreen Senior Member
    13,712
    4,231
    Austin, TX, USA
    yes, I can feel the cooling 102 degree temperatures.
    There is enough variation for people to claim cooling in the short run, even as things continue to heat up.
    CLimate is 30 years. A few years of cooling will likely happen even in a warming world, just as warming happened at periods in the ice age. When it warms on average for 20 year periods, there will be something to look at.
    Can we stick to climate science and not politics.
    I agree we should not use drones, unless there is an imminent threat or other ways to capture. I approve them on enemies of the US, when these things are not possible without a great deal of loss of life. I don't think either was the case with the Americans hit. There have been some good drone strikes though. I am more concerned with the loss of freedom in the patriot act and nsa spying. Like the drone strikes these were bipartisan policy, and they need to be reformed.
    Problems with presidents and killings are not new. Here is clinton
    THE CLINTON BODY-COUNT
    Bush
    Prosecute George W. Bush for Murder
    Name the president you liked most, there is a list. Some of it is fair, most of it isn't, but no commander and chief is clean.
  7. tochatihu
    9,906
    3,836
    2001 Prius
    The predictions of the next solar cycle being lower than the current were based on the current one not getting nearly as high as it has. We have been through all that before (should I post again the link to solar-cycle records?). The prediction makers have been quiet, so the chirping crickets thing fits in that regard.
    There were two weak cycles back to back around the turn of the 20th century and that did not lead to another maunder minimum nor a mini ice age. Thus it seems quite speculative that another weak cycle after this one would turn out that way.
    Yet, we are all free to speculate.
    Yes the solar magnetic field reverses every 11 years, except during Maunder minima. The latter really are a big deal. They remain unpredictable to science, and apparently so to 'almost science' as well.
    I use my freedom to speculate that ocean heat redistribution patterns have much stronger climate effects than solar cycle. It has been that way since instrumental T records began, so it does rise a bit above speculation eh?
    How much warmer the next decade will be than the current, appears to depend on the oceans. The CO2 increase is already locked in by economics, and its direct heat trapping effect is a matter of physics. Amplification of that effect by water vapor and biological processes remain uncertain, and one does not need to read a huge number of papers to find that out.
    But again, the 'each decade warmer than the previous' has held up over the last 4 (or 5?) solar cycles, so it does not look like heavy speculation.
    How much warmer? Aye. We are 'captains of the ship' in terms of CO2, but we do not command the currents beneath the keel.
  8. tochatihu
    9,906
    3,836
    2001 Prius
  9. bwilson4web
    16,485
    My understanding is Voyager I position in the heliosphere is determined by the solar magnetic field. I'm wondering if Voyager I and II will detect the solar magnetic field reversal?
  10. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I'd say so after the 15-20 min delay for EM to make it out that far.
  11. tochatihu
    9,906
    3,836
    2001 Prius
    I went again to the Montana SPD page and they have still not posted presentations. Frankly the only one I want to read is Penn and Livingstons so it might be simpler to just ask those authors for their ppt.
    I just want to know the evidence that the next solar cycle might be less than the current. Or go to zero. What with CME causing typhoons (ask mojo and Piers Corbyn about that) it seems important.
  12. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    They have examined the interior of the Sun and determined there will be lesser solar flares.
  13. tochatihu
    9,906
    3,836
    2001 Prius
    Just so. In their 2010 manuscript
    arXiv:1009.0784v1
    the data looked like this:
    I am interested in their 2013 solar physics workshop presentation but it hasn't yet been posted. I am interested specifically because these are forward extrapolations, from rather variable data, over a period equal in length to the data record. Not everyone would be comfortable doing that. Do data current through 2013 fit this extrapolation?
    It appears to be just you and me, mojo, interested in this at PC. I wish it were otherwise. Perhaps if people read the 2013 Forbes article
    Keep Your Long Flannel Underwear: Climate Scientists Predict Hell To Freeze Over! - Forbes
    including the author's correction at the bottom, we could get some others interested.
    mojo likes this.
  14. tochatihu
    9,906
    3,836
    2001 Prius
    Dr. Livingston replied to my email and sent the following graph. It is not yet in a peer-reviewed publication, but if he says it's the data then by golly it is, until further notice. He also sent additional material that explains how the measurements are made and their potential significance.
    I do not interpret the data, average trend , nor extrapolation. I will mention that his email stated "too early to predict the next solar cycle", and I think that matters because Livingston (and Penn) are known outside the solar physics community because of extrapolations that have been made.
    Look, he was quite approachable by my 'cold call'. I think he would be to your emails as well. I shouldn't approach him (or Mann, or anyone else) by saying "you're way off-base, justify your thinking to me". But that's just common courtesy.
  15. bwilson4web
    16,485
    Doug,
    Something bothers me about this chart:
    Notice how the peak intensity appears to clamp at "1.0" which suggests hitting a sensor limit. If the peaks are under reported because the instrument can not handle the full range of values, it would have the effect of giving a false indication that rate of solar output is flattening out. Worse, a trend line based upon sensor clamped data would be inaccurate.
    The reason I'm sensitive to this effect is I deal with computer network data and have often seen saturated circuits. The data plateaus and if the engineer is not clever enough to look at the discards, can fail to see how badly the circuit is overloaded.
    Thanks,
  16. tochatihu
    9,906
    3,836
    2001 Prius
    I think it is explained in the other documents I received. But very briefly, there is no difference between the the brightness of the spot and that of the surrounding solar surface.
  17. bwilson4web
    16,485
  18. tochatihu
    9,906
    3,836
    2001 Prius
    The endless hunt for something, anything that opposes the climate-change mainstream features grasping at things that to me, often resemble straws. Livingston's research looks like one of those, because the newest umbral magnetic field data look, well, pretty flat. It doesn't strongly support an upcoming collapse of sunspots. To be fair, neither does it exclude the possibility.
    To what extent Livingston and Penn 'fueled the fire', I don't know. But one must look at the data first, and I think this is a good example. There are data, there are extrapolations, and there is affinity-website spin. Besides this one, we can see it by way of Grinsted, Alley, and gosh I don't know how many others. Most recently, Wyatt and Curry (ya'll haven't seen that yet maybe).
    To me it makes sense to pay most attention to the data. We live in a world where extrapolations and spin offer a 'no-think' alternative and I oppose that. Data from different fields that 'hang together' and present consonant information is like gold in this troubled world.
    The ocean long-term heat-transfer thing is still there, and still (in my view) interfering with casual acceptance of IPCC AR5 projections. But this is a solar thread, and we'd better talk about the oceans somewhere else. In that other place it would be fair to ask about the models presented by climate-change mainstream dissenters. I don't know of any; not even one. Perhaps that is a travesty.
  19. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    "If you're climate scientists, where are your models?"
    "Models! We ain't got no models! We don't need no models! I don't have to show you any stinkin' models!"
  20. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
