Solar panel on roof
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eric smith, Oct 26, 2012.
  1. bisco
    52,855
    it must work really well for you to be so enthusiastic. i don't recall others feeling the same way hopefully, with positive feedback, they will make it an across the board option.
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    The solar panel pulls some outside air into the cabin. It produces way too little power to operate the A/C, which would be required to do any significant cooling.
  3. Drake
    Drake Junior Member
    71
    16
    Quebec, Canada
    2013 Prius Plug-in
    At 60 Watt, you would need 53 hours of full sun exposition to recharge 3.2 KWH of the Prius Plug-in battery...without even considering conversion lost.
    Also, I found this interesting old article about solar panels:
    Kyocera offers details on solar cells used by 2010 Prius
  4. 3PriusMike
    3,101
    2,421
    Silicon Valley
    The conversion losses would be much bigger. We already know that 220v charging is more efficient than 110v charging. (maybe by a few percent...but this might be 10-12% losses compared to 13-15% losses). Now try charging with only 12v. Maybe 25-35% losses. This is about the losses you get with phone chargers and they aren't stepping up the voltage from 12v to hundreds of volts as well.
    Mike
    Drake likes this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't mind it being an option. But I'd be miffed if it comes standard just like I am miffed I had to pay for standard heated seats and the next to useless NAV. The function of a cooler interior can be accomplished by remote AC which costs considerably less and works works as well without the added weight of the solar panel..
  6. lensovet
    2,615
    496
    Burlington, NJ
    Dude the heated seats are genius. I've always thought them to be a useless gimmick, but after driving through a couple of days of sub-50° weather, I love being able to just keep them on and not worry about ice usage.
  7. 3PriusMike
    3,101
    2,421
    Silicon Valley
    +1 (PIP)
    +1 2010 and PIP passenger
    Mike
  8. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    That means by the time you add 5,000 lbs. you could get 0 mpg. :cautious:
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I think if you placed a 5000 lb weight on the car it might not ever go anywhere. :)
    Mike
    JamesBurke likes this.
  10. mmmodem
    2,732
    1,703
    Bay Area, CA
    Meh, Long John's and a blanket. Give me back my money, Toyota!
    Fine, I do like them. I use them occasionally. But I can easily do without them.
  11. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    The weight of the solar roof panel + the expense of said panel and production costs for a variation of actual body = no.
