Solar panel sun shades
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hopeful_Optimism, Aug 18, 2011.
  1. Hopeful_Optimism
    Hopeful_Optimism New Member
    El Paso, TX
    Hi all,
    I was checking online for flexible solar panels, and I think that they aren't too expensive. I own a 2010 Prius II, so I'm sort of envious of the other trim lines that have a solar panel and can vent the fans during hot summer days. Is there a way to integrate a sun shade with flexible solar panels into some electrical port that will turn on the fans when the car is off, or does this require software and is basically not do-able?
    Thanks in advance if you're able to point me in the right direction.
