Solar Plane Successfully Completes Maiden International Flight
Discussion in 'Environmental Discussion' started by Rybold, May 15, 2011.
  1. bisco
    52,829
    so cool. i wonder how much energy was used for take off compared to the total flight?
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Actually, the real conceptual difference is that solar panels don't get lighter as the flight progresses.
    A real practical issue is that the energy density just isn't high enough yet. Cloud cover is a minor inconvenience for long flights, just fly above it, especially in a plane which doesn't need oxygen for combustion.
  3. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Video: Solar Airplane’s Maiden European Flight | Autopia | Wired.com
    IMHO if you don't put seriously bigger batteries in the plane, every flight will be a long flight. Climbing above the clouds takes a great deal of energy, and in this plane time.
  4. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    this is awesome.. I feel like I am going to see something cool like space flight in my lifetime..
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    And bigger batteries aren't heavy? At present, batteries are just about a break even proposition: the batteries are just about powerful enough to haul themselves into the air, but not for any appreciable length of time. This means that effectively all of the power comes from the solar panels for anything longer than a trip around the patch.
    Tom
  6. austingreen
    13,714
    4,232
    Austin, TX, USA
    If you look at the project page, the plane is designed to run on battery power all night, and has completed a 24 hour flight. It says the primary limitation on performance is battery capacity, which is what I wrote. Battery weight is a problem and currently is about 1/4 of total weight. The solar panels need to be big enough for cruise and storage power, the batteries big enough to take off and accelerate and maintain speed at night.
  7. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    I remember watching interview with plane designers few years back, and they talked about night flight. They actually use surplus of solar panel output to climb during the day, and during night they descend and loose something like 7-12,000' . Not a bad strategy, much better then carrying bigger batteries.
  8. qbee42
    18,058
    3,081
    Northern Michigan
    I was just going to make this point, but you beat me to it. I assume they used a similar strategy with this new aircraft, as it uses the weight of the aircraft to store energy.
    Tom
